05 GTO clutch issue
05 GTO clutch issue
I have an 05 gto m6 with just over 17k. The problem Iam having is that when Iam runnin her hard the clutch pedal does not seem to give proper feel and or seem to come off the floor. This is an ongoing problem I have flushed the entire clutch system and replaced the fluid seemed to be better, but still a problem exists. The fluid was horrible when I flushed it out. Acts like slave cylinder is hanging up or sticking. Heat does not seem to factor but higher rpms do. If I shift below 5k no problems at all but the second Iam up in higher rpms (ie: limiter ) thats when the problem accours. SO I gues the question Iam asking is instead of putting a factory slave back in the car does anyone make an a good aftermarket slave for the GTO's
Swap to a F-body slave cylinder and while you have the transmission out just swap clutches to an LS7 or Spec 3/+. Sure the stocker should technically go more/last longer but all the work for the trans to come out may as well put insurance back into it...
But yes, sounds like to have the crappy slave issue that pops up here and there.
http://www.ls1gto.com/forums/showthr...slave+cylinder
I smoked my stock clutch with 3K miles at the strip on MT ET streets launching at 3800-4000, I am currently looking into a twin disk setup as soon as a save a little more $$$, I want to do it once right!
I have noticed that my car does something like this. When I am running her hard, I have noticed that with every shift the pedal has less and less travel. It has gotten to the point where 3rd to 4th feels like the pedal doesn't hardly move at all. Still shifts fine with no grinding or increased effort, so I assumed it was normal.
just get a new slave and ls7 from scoogin dickey-- i went with them cause there kit comes with the flywheel. oh and a remote bleeder. hey k-town i am trying to get orders to germany--but have to wait and see.
When you depress the clutch pedal you can see the hydraulic lines balloon in our cars. I am also going to put high pressure hydraulic lines in along with the remote bleeder. The question I have is will the FBody hydraulic line that fits the FBody fitting on the slave also work with the Master Cylinder on the GTO? I honestly believe that replacing the slave is a good idea but I think a higher pressure hose is essential.
At GMParts there is also a Master Cylinder rebuild kit. I am wondering what it consists of and is it necessary?
