Pontiac GTO 2004-2006 The Modern Goat
cam for ls1
Old 11-18-2007, 12:11 PM
oopakyle's Avatar
Default cam for ls1
Well I'm looking to get my 04 GTO to about 350RWHP. I'm going to be doing full exhaust, and a cai. What cam is going to get me to my goal and idle pretty good? TIA
Old 11-18-2007, 01:39 PM
batboy's Avatar
Most cams, even big ones, will idle good if you have a good tuner. Yes, even a small cam will require a tune. When you say you want it to idle good, do you mean without a lot of lope? Lots of factors to consider. Is this a M6 or A4 car? If A4, are you going to swap in a higher stall converter? Is this a daily driver? What valve springs do you plan to run and what other valve train updates do you intend to do (if any)? Do you want to retain as much low and mid range torque as possible or do you want high RPM HP?
Old 11-18-2007, 02:41 PM
ArklaTexan's Avatar
CAM ONLY
Idles at 890 Nice and clean, it's all in the tune. And in pulls like a freight train!
HPE Mega Death 244/242 6.12 lift 112lsa
Old 11-18-2007, 05:33 PM
GoatChzLS1's Avatar
Originally Posted by ArklaTexan
CAM ONLY
Whats with the crazy spike of over 20 afr at max?
Old 11-18-2007, 05:35 PM
ArklaTexan's Avatar
It was being dyno tuned this was just one of the runs, the 20 spike was an error but the 14.4 was not. Needless to say we got everything down to where it should be.
GoatChzLS1's Avatar
HPE c cam will get you more power then that and idle very nice.
Old 11-18-2007, 07:21 PM
batboy's Avatar
Why are you guys showing him the dyno for a big cam when you don't even know all of his goals? I would certainly not recommend a Mega Death cam for a daily driver. That is too much of a sacrifice in driveability. Let me guess, you will now try to claim it drives like stock in stop and go traffic. I'm within about 25 HP of your monster cam with my little baby cam and I have an A4 which don't dyno as well as the M6.
Old 11-19-2007, 04:05 AM
Rob
Rob's Avatar
LPE GT2-3. It will idle like stock and nobody will know there is a cam in there. I had Dynatech long tubes and cats into the stock catback, Speed Inc cold air, SLP pulley, 160 t-stat, and a tune. 368/360. Added GMPP LS6 heads, 393/380.
Great baby cam that runs like stock. I even rode around with the stock tune for a couple of months without any problems. Your goals don't need a big cam at all.
Old 11-19-2007, 10:15 AM
ArklaTexan's Avatar
You Have LS6 heads!! You can't compare that to a cam only, and if you did you still lose out. Did you dyno on a Mustang Dyno?? I doubt it, besides unless we run our cars on the same dyno the numbers are worthless. On a typical dyno jet my car would be 15-25 whp higher. A Dyno is just a tuning tool. And how would you know the drivability of my cam, have you driven it?? I have never had a cam in a car and this drives wonderfuly for the power I have added. If you want to compare timeslips than that would be fair, otherwise we are just in a pissing match with dyno numbers unless we are on the same dyno and compare where the power comes on.
End of my rant.
Old 11-19-2007, 10:17 AM
GMLIFER's Avatar
Talk to who ever is going to do your work, tell them your goals. I know you say you only want 350 to the ground but as soon as you get it you will want more. I had 238 242 .605 .610 113 and it sounded great and made great power. The idle was good and pulled awesome up top. Whatever you decide good luck and enjoy.
Old 11-19-2007, 10:20 AM
ArklaTexan's Avatar
When I put heads on my car (like you already have) I will be closer to 460 so you are within 65whp with your baby cam, whooohoo that is close.
OOPAKLE, all arguing aside it really depends on what your goals are for the car down the road. Do you want people to know you have a cam, do you mind a slight shimmy at idle (Personaly I think its cool). Now a days with a good tune the car will idle just fine. Send me a pm and I can discuss this with you further, If you prefer to talk in person you can give me a call,
Take it easy.
Old 11-19-2007, 11:17 AM
batboy's Avatar
Hope you have good valve springs and upgraded valvetrain to take full advantage of the high RPM HP. Since 95% of my driving is below 5k RPM, I prefer useable power in the low to mid range. It's a matter of personal preference. To each their own. Glad you like your big cam and hope it's fitting into your goals, enjoy. But, that don't mean it's right for everyone. We still need more info before we can make a reasonable recommendation for Oopakyle.
Old 11-19-2007, 11:22 AM
DANOZ28's Avatar
i like to say dont make the mistake i made with cam, i got the LS6 2002, 550 lift 218/204 dur w117 lsa. no lope sound and idles 600 rpm. fyi any high lift cam needs better springs. a popular cam on the board here has been the tr224. good luck!
Old 11-19-2007, 03:19 PM
CABRO's Avatar
well if you only want 350 then you should be able to achieve if not come really close with just blot ons........ udrive pulley, ported tb to go along with the exh.... and by full exh. i am thinking your getting longtubes as well.
Old 11-20-2007, 07:34 AM
CABRO's Avatar
plus i wouldnt go with the mega death cam.......... ONLY WIERDO'S GO WITH THAT CAM.
who the hell wants to go that fast.......
Old 11-20-2007, 07:53 AM
ArklaTexan's Avatar
Me, Me, Me, Me, Me, and you! We love the Mega Death cam, it kicks MEGA @$$.
Old 11-20-2007, 08:19 AM
walterd's Avatar
put a 224 in it, you and your car will be happy
Old 11-20-2007, 04:50 PM
oopakyle's Avatar
My goals aren't a high rpm car. I don't go to the track anymore so this is going to be a strictly street driven car. It's an M6, forgot to add that I guess. Does anyone use the hotcam anymore? I guess it's probably outdated a long time ago, but I've had it in an lt1 and it was pretty good. I've never owned an LS1 before, 350rwhp can be had with bolt ons? Besides full exhaust, what else would be needed? I can do all the work myself so that'll help keep the price down. Also don't have any plans on upgrading the vavletrain right now except for vavle springs if needed. So again, no super RPM monster lol.
Old 11-20-2007, 06:53 PM
big reg's Avatar
Why are you people even recommending cams for this guy when all he wants is 350whp. That can be obtained with boltons. I would recommend him my cam in my sig but his goals can be obtained w/o one.
Old 11-20-2007, 07:32 PM
ArklaTexan's Avatar
Because people always want more than they say. Your are correct that he can get there with boltons. If he wants to keep it stock sounding he could get a smaller cam a fast intake and UD pulley and will still sound stock but put down some good power. He could even add some heads. If he wants to keep it quiet he just has to choose hit headers and exhaust accordingly.
Quick Reply: cam for ls1
