Shifting to 2nd issues?
just picked up the car on saturday (new to me)
babied, so maybe i'm not used to the car
GMM shifter, RPS clutch
shifting into second slowly, intown etc no problems
if i get on it a little bit, she'll grind as it goes into gear??
-I've tried making sure I have the clutch all the way in
-Different ways I hold the shifter
-Called the previous owner and he recommended that maybe i'm not being "firm" enough with the shift. I did notice once tonight, if I was firm, but not really hard on the shift, it'll go into gear, but sounded like it just grinded for a second? (because it was a faster, harder shift?)
It's weird...its probably me not being used to it??? I hope its not the syncros or anything...
but keep in mind I don't have problems with any other gears
i go to meets with a bunch of GTO guys and have never heard anyone complain about a 1 to 2 gear grind. i would definately keep an eye on it if not call a shop that specializes in t56s and see if there is a problem that can easily be corrected
tried the firmer shift, no luck
Pretty much anything above 2k rpm causes a grind
Called Amber at Six Speeds Inc, she said I should convert the stock slave to an adjustable slave. She said a blocker ring could have gone bad, but like all of you said, Bob was so easy on the car, and I've been even easier on it.
I might try bleeding the clutch, but I don't know why there would all of a sudden be an air pocket in there now??
Did some more calling, more asking
Hydrualics are probably OK
Likely it is the blocker ring for 2nd gear, and it's not letting me easily go into 2nd. Which means I have to pull apart the trans
BUT I need to talk to Bob (previous owner) and ask him about his clutch. It's an RPS clutch, and I don't know whether he installed it or whether EPP did. He said he had similar issues after the clutch install with 1st AND 2nd...after EPP rebled the clutch, it seemed to fix the problems.
My other car guru guy said that maybe the clutch needs some shimming being the throw out bearing, because maybe its not releasing all the way. Bleeding it at the beginning could have fixed it slightly and now second seems to be the issue.
So does anybody have an RPS clutch, I need some info on possible shimming.
Because I rather shim the clutch than tear apart the trans (I rebuilt my trans over the winter)
help
help
i put in motul 600 synthetic, bled it and it cured my probs with a spongy clutch pedal and probs shifting after a run from the fluid boiling. it is better than dot 3 or 4 and its dry boiling point is close to 600 degrees
radkon - yeah it just started to happen...Bob didn't notice a problem either, but then again, he said he never drove it that much to notice it! haha
Where can I get Motul 600 synthetic?
I don't think I'm having heat issues, as the car has stock exhaust manifolds on it, but the supercharger does make some heat
My WS6 will boil the fluid with the headers on the car...
I have an RPS clutch in my car too and have the exact same problem. Shifts at low rpms no problem high rpms and you are not able to find a gear. I spoke to someone and they said it POSSIBLY could be the headers boiling the hydraulic fluid. So I am going to buy this braided clutch line.
If you wanted, you could buy some heat resistant material to wrap around the line that is near the header...litterally about 6" is probably all you need
sure beats $240
Here's at update
this past week I parked the car, because it was starting to give me issues even putting it into 1st gear....made me start to think that the fluid was burnt
so I just flushed out the system with new DOT4 fluid
Started the car, gave me a slight grind into 1st again....****
BUT It wasn't as bad
drove it up to the car wash to clean the underside from the burnt brake fluid...which was BLACK by the way lol
going into 2nd wasn't really an issue anymore. It did grind once going into second at higher RPMS 3k-4k but again, it wasn't AS bad
so the fluid def was part of the issue...I still have the lines on order...but I don't know how much that will improve it.
I spoke with the clutch company (RPS), the owner actually. He said he could have me send in my clutch and give me a "healthy" discount on their new twin disk setup, which has a lot less peddal pressure ---therefore it should fix any disengagement problems
awesome...just don't have the cash for that since its a really $$$ unit
whata ya think?
whata ya think?
Here's at update
whata ya think?
whata ya think?
HMMMM wonder how much off he would give on a trade in??
For 1200 you can get a Tex Twin, and now that I know how badass a clutch it is...When this goes, I would pay 2g for the same clutch...I have beat the **** out of this one for 4 track days and 8k miles....1.6 and 1.7 shorts all day long....
wrencher
For now I'd say a quick thing to also do to help would be to change the fluid out in the trans as well. The adjustable master would also be a good idea IMO. Getting all the play out of the pedal will help shifts tremendously.
