jost got home from norwalk new PB!!!
the track prep sucked and so did my 60's
set up is 04 gto
3500 edge verter
11.82 scr 346ci
cometics .040
afr 205s 59cc
pace setter lt's to 3 " mids no cats to flowmasters
xer 238/242 .605/.609 112lsa
bfg 275 dr's.nos wet plate kit,slp underdrive pulley
best run with 150 shot with window switch set at 4100 on (due to no tracion) off at 6900
60-1.851
1/8-7.345 @98.30
1/4 11.293 @125.12
not the 10.99 i wanted but with a good 60 i think i might be able to get closer
no spray best run
60-1.806
1/8-7.898@88.86
1/4 12.355 @109.94
last time i ran it bone stock except the verter with a 150 shot i ran 12.22@111 so i was real happy that heads,cam and exh came damn close
Plus i have a ls1 intake on it right now i bought a umi 90mm tb but don't have the funds yet for the fast. so hopefuuly with that,drag bags and a good dyno tune i can get in the high 10's even if it was a 10.99 i would be happy
I will have a vid up by the end of the weekend and i will post the link
set up is 04 gto
3500 edge verter
11.82 scr 346ci
cometics .040
afr 205s 59cc
60-1.851
1/8-7.345 @98.30
1/4 11.293 @125.12
no spray best run
60-1.806
1/8-7.898@88.86
1/4 12.355 @109.94
here is a vid of a 11.61 @122 run not the best vid i will have a good one by sunday
http://s54.photobucket.com/albums/g8...kFall08014.flv
thanks man, i got her on jack stands right now. i never drilled the 2-3 shift hole in the spacer plate when i put the trans go kit in.
would not shift from 2-3 till 7200 and flat as hell i know with some drag bags and getting that shift point fixed it will do better.
I am learning that the faster you go the more spot on everything has to be
