2007 Santafe 3.3l issues - LS1TECH - Camaro and Firebird Forum Discussion
Thread Tools Search this Thread
Old 03-22-2017, 09:30 PM   #1
Default 2007 Santafe 3.3l issues
hi folks, excited to be here. I have been battling with hard starting of my Santafe 07 3.3l for 2 years, anytime i want to start the engine especially if the vehicle is parked for over an hour or cold., engine cranks twice before starting or starts and then goes off but starts at second attempt. the only DTC is P0420 and P0430.
Noticed couple of exhaust leakages at the joints and have so far replaced all the gaskets on the exhaust system. code clears and comes back again. on the starting issues, i have replaced CMP, speed sensor and fuel pump assembly(3 times). Its having a toll on the battery, having to replace batteries every 4 months. vehicle drives smooth when engine starts. . please can anybody decipher this and also assist me to solve this cranking issue. I am at my wits end. By the way i have 2 scanners Launch 431 pro3 and TOAD.
MODE$06 onboard monitoring
Cid $60 TID$04 manufacturer Defined value 160 min.160 max N/A results Fail
cid$70 TID$04 manufacturer defined value 45 min 160 max N/A result Fail
gosh! my name is Gerald
AC Enguneer is offline   Reply With Quote
Old 03-23-2017, 08:41 AM   #2
mcG
Welcome Gerald! There are quite a few Hyundai Santa Fe experts here on our LS1 site, so I'm sure they'll be along to help you shortly.
mcG is offline   Reply With Quote
Old 03-23-2017, 03:04 PM   #3
BlackonBlackTA's Avatar
Cut the catalytic converter off, and run that bitch straight piped.
If that doesn't work, I would try submerging it in water. Submerge what you might ask? The whole damn car.
BlackonBlackTA is offline   Reply With Quote
Old 03-26-2017, 10:14 AM   #4
TheSilverOne's Avatar
or set it on fire
TheSilverOne is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
How to Find a Parasitic Battery Drain ProStreetDriver Advanced Engineering Tech 0 10-16-2017 01:58 AM
911 LS3 Swap: Stalls and hard to start when hot rdymond Conversions & Hybrids 18 07-01-2017 09:35 PM
LS7 help trevmust Generation IV Internal Engine 38 06-11-2017 01:18 PM
5.3L Issue - P0171/174/300 Atrus_SS Generation III External Engine 3 02-15-2017 09:02 AM
LS1/LS6 Engine Dimensions & Clearances J-Rod Generation III Internal Engine 20 05-19-2016 06:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
