Non Adjustable Bilstein vs Double Adjustable Koni
How do the non adjustable bilstein shocks used in the slp eibach/bilstein combo compare to something like the double adjustable konis that are four times as expensive. In some casual HPDE track days am I really going to notice a difference?
Konis will be a pretty big change over the bilstiens, they offer way more rebound control. Also you don't "need" the DA's, go with the 4/3 SA's. Most people with DA's end up running the same compression setting that the SA's come fixed with anyway, so you might as well save money and go with the SA's unless you think you want the compression adjustable as well (like if you plan on adding more unsprung weight).
DA koni's would be better if your adding weight to the car...bigger block, turbo setup, etc..DA's will allow you to manage the weight across different track surfaces...
i run the SA's on several different types of track and they perform very well...Stiffer springs would be welcome, especially in the front. I currently run the 550lbs/in in the front and rear is 150lbs/in working rate...
if i could do it all over again...i would have bought the KW V3s and forget it...way way easier to get stiffer springs for and excellent range of adjustability..
Go with the SA's you'll be fine.
Brigade24; you can use any rear pigtail spring that you find abound in circle track catalogs. Find the height, stiffness and color you like and have fun...
thanks km, that would certainly simplify my life...inner diameter doesn't matter or is that what the color represents? i guess i could do my own research on this..
Nah color is just what each company wants to paint their stuff. Any standard 5 inch rear pig tail spring. They come in all lengths and stiffness. You can fine tune a little bit with the upper isolator.
For the front you can run the 5 inch coilover kit from coleman on your SA's just fine. Any 2 1/2 inch front spring and you're good. Again length and stiffness is limitless.
** Also, if you are on the more serious side, do some research - Konis can be sent with the "off-the-shelf" settings or be re-valved for more specific use.
Good luck
How about Bilstein vs KYB AGX? Pretty even on price so maybe better for comparison. I know KYB quality and reliability is questionable but can the adjustability allow for better handling than the Bilsteins?
If you can afford Konis, they are the cats meow. Otherwise, Bilstein.
case in point, when i did my suspension, i went with koni 4/4 SA. i was doing autox semi regularly, then went to 8ish track days a year. i set them once during the instal, and never touched the settings again. through 4yrs of track days, not once did i ever adjust the konis.
i built a 3rd gen dedicated track car. i have a mismatched suspension for now, but when i get to buying a complete setup, im more then likely going with non-adjustable bilsteins. its a track only car, with very limited street use, but still....maybe 5-8 track days a year wont justify $1000 shocks over $300 shocks, for my specific case.
For a thirdgen the shocks are way more than a fourth gen koni or bilstien. I have koni's on a 4th(came with SLP Bilstiens) and I have Bilstien HD's on a 3rd gen. The konis & Bilstiens are over $750 a set for a thirdgen.
When I went koni on my SS over the slp Bilstiens i noticed a dramatic difference in handling and stability, not that the bilstiens were bad - they are not. But performace wise there is no comparison. In Bilstiens defence they are a nice street/ daily driver shock. But pure performance Koni all day every day. Unless you spring for custom valved not off the shelf bilstiens, but these are not an option if cost is concerned.
