Lug nuts for racing
Lug nuts for racing
Not sure if this should go here in road racing or wheels and tires, but felt like road racing would be more fitting as I'm looking for function over form.
I ended up freezing up 2 lugs on a couple of my wheels after racing at a private track day event. Never put much thought into my studs and lug nuts but obviously I will need to take care of that now.
I plan on replacing all my studs with extended ARP studs but not sure where to go with the lug nuts. I'm thinking open ended lug nuts, I like the TWMPerformance titanium lug nuts but no way in hell I'm spending $450 on a set of lug nuts, I'd like to keep my limit to around $100. The Anodized aluminum lug nuts from improved racing seem good, anyone have any experience with them?
Thanks in advanced.
Thanks in advanced.
I run the improved racing lugs on my ARP studs. four of them weigh about the same as a single steel nut. You just need to make sure you thread them by hand and torque them with a toque wrench, by hand. I've been running them for a year on my Z06 wheels and never hand any issues. I can give you a code to save you some bucks if you buy from Improved. PM me if you're interested.
Just go to your local auto parts store and get some open end nuts from Dorman. Steel, cheap, quality plating so they don't rust, and nice rolled threads. Lug nuts really aren't the smartest place to save weight. Seen many aluminum lugs pull the threads out.
Well already ordered the Aluminum ones and they should be fine for me on my application with some ARP studs and to be honest I'd rather the threads on the lug rip off instead of the lug taking my stud with it like it did to me earlier kill a lug just replace, kill a stud and your done racing until a new one is pressed in, but I'll go ahead and pickup some dorman ones as backup. Thanks for the tip.
