Road Racing Road Course | Autocross
Spring spacers?
Old 02-10-2017, 12:47 PM
STANG KILLA SS 2's Avatar
Question Spring spacers?
as crazy as it sounds im looking to do some rallycross with my camaro.
but ive got BMR springs on it now (1.25" drop?)
are there any spring spacers out there that can go on without removing the springs off the struts? ie like a horseshoe shape? some how held in place?
this is a temporary endevor and i dont want to remove the springs to do it.
rears are easy enough,
also does anyone know the outer diameter and height of stock springs?
Old 02-10-2017, 01:46 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
Well, this is different but I do have an option for you that is easy and temporary. Our SA002 shock spacers will raise the car 1/2", and simply install under the lower shock mount bolts at the control arm. These can also be double stacked to achieve 1" of lift , but will require longer and higher grade hardware
http://bmrsuspension.com/?page=produ...506&superpro=0
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 02-10-2017, 02:51 PM
wow thats awesome didnt know there was such a thing! with those i wouldnt even need to compress the coils would i? just unbolt struts at top and install spacers and longer bolts? love all my other BMR items.
Old 02-10-2017, 03:06 PM
smitty2919's Avatar
I don't even know what to think of this...
I try to AVOID the grass at all costs LOL
Old 02-10-2017, 03:34 PM
and it looks like split/horseshoe coil spacers are also common.
just need to find out what diameter my bmr springs are. i think i still have my old Eibachs i could measure.
Old 02-10-2017, 03:44 PM
BMR Sales2's Avatar
As an alternative if you need more than that, you can find a local circle track racing supply shop and get spring wedges. F-body front springs have a 4-1/2" OD and 3-1/2" ID, so they should have something to fit these needs. they are made to be quickly and easily removeable and installed
__________________
Glenn ***
Sales Tech
813.986.9302
Old 02-10-2017, 03:45 PM
BMR Sales2's Avatar
Correct, just let the suspension free hang, unbolt the shock and pull the arms down farther. Put the spacer in and bolt back up
__________________
Glenn ***
Sales Tech
813.986.9302
Old 02-16-2017, 02:27 AM
DietCoke's Avatar
cut up some hockey pucks
Quick Reply: Spring spacers?
