Best 200TW tire for autocross?
I raced my first autocross last Sunday (came in 2nd). My Z originally came equipped with Trofeo R's which are a TW60 or something, but I bought the car with Potenza's which are currently a TW140. They let me slide because it was my first time, but told me if I were to win then they'd either bump me to a tougher class or force me to change tires. Next event is July 15th so there's plenty of time to make the switch.
I was told that the Bridgestone Potenza RE71 is a great TW200 tire, but I've only heard from a few people. I'd like to hear some more opinions especially guys that have run several different brands. Either way they're crazy expensive in my size 305/30/19.
I've been using the Rival S for a little over a year now (315x30R18 on all 4). They are great tires but they wear super fast (like all 200TW will). They are stamped 200TW but realistically are probably more like 150ish. I am due for a new set and that sucks because they run like $1,600 before mounting costs.
Thank you guys! They are crazy expensive due to the size I have, 305/30/19. I'm probably going to get an extra set of wheels for track use only.
I thought drag racing was expensive lol
EDIT: I just looked and apparently they don't make the Rival S in my cars size yet. Bummer.
All I am saying is the manufacturer assigns the treadwear ratings that are not controlled by the government. So if they are advertising to a particular group of people (auto-x) they will meet the needs of the masses (200TW). Treadwear numbers are very subjective.
All arguing aside any 200TW tire will not last very long. Just be prepared OP.
That’s why I never understand why autocross events put a restriction on TW rating. The manufacturer gets to pick their TW rating! Can’t compare them between two brands unless you know what tires they based the measurement off of.
That's what I was trying to get at so thanks for putting it that way. It would be nice if the treadwear ratings had a true measurement stick to go off of between the different manufacturers.
TW rating is also measured based off how many people run them what the 1st place people are using. If a company can dupe the industry putting a 200TW stamp on a tire that is more like a 100TW tire, people will run them until someone complains that the tire is "unfair" at which point they will ban that tire. I believe SCCA banned the factory Viper ACR Kumho tires.
Rival is your best bet in a wide tire since Bridgestone does not come in a 315/18. Expect to spend about $1000+ on new or $300-800 for used.
Oh and get rid of the 19" wheels.
EDIT: front rotors are 15.5", and rears are 15.3", figure the calipers overhang 1" or so.
Waiiiiit. What car are we talking about? You have a '94 Z28 and a '15 Z28 in your signature. I assumed we are discussing your 94, but I feel my assumption is wrong.
If discussing a 5th Gen Z28, I don't know what will fit on those. You can get a hold of JDP motorsports (Jordan Priestly) who ran 5th and 6th Gens heavily in Optimal etc events.
Always take a look at the specs of the tires you are considering, in the case of the 305/30-19 the Hankook RS-4 has a tread width of 11.4" compared to 11.1" on the RE-71R.
Just like treadwear ratings, the actual tread width is at the discretion of the tire manufacture, the actual tread width on all of the available options may be as much as 1" to 1.5"!
The fastest guys usually figure out which one of the cheater tires runs the widest and figure out a way to make it work. We did this in NASA before they came up with their own way to measure actual width.
In some cases a more narrow tire will be faster due to a better compound, but more often than not width trumps compound - as long as the compounds are close (which 200 treadwear tires should be).
^^^That is the run that put me into 1st place briefly. The Porsche Cayman you see in the background in the beginning ended up beating me on the last run.
