Enclosed Coil Rocker Covers for LSX!
In case you're not familiar with us, we currently offer a 2 piece, total replacement for the stock GM valve covers found on your Gen. 3-4 V-8. These covers have additional internal clearance to make room for extra valve lift or a set of aftermarket rocker arms. They establish a leak proof seal via the stock bolts (we provide new grommets) and a stock-style o-ring gasket. The Abear Enclosed Coil Valve Covers also feature a patented Coil Cavity which hides your ignition coils in a stock-like location, and allows the use of factory length spark plug wires.
Please check out the updated www.AbearMotorsports.com for more information on available finishes and applications.
Have you had any of these out there that have been in constant use in a daily driver?
Reason I'm asking: do you envison any heat soak problems with the coils totally encased in this fashion without any ventilation?
BTW, they are BEEEEEEEEEEutiful!
-Jay-
We get this question a lot so we will be posting some results from our coil testing in the next week or so. Without going into all the details I can say the coils withstood temperatures in excess of 350 degrees for over 30 minutes without malfunction. If an engine ever sees 350 degrees the coils are the least of your worries...
Maybe I can convice you at that time to have a christmas sale
I like this option much better that the traditional coil pack relocation.
Forgot to add: We generally ship 2 weeks from the time we recieve payment and any engraving is finalized. Add 1-2 weeks for any powdercoating or anodizing.
sweet.
