New Trans Mount, New Noise?
Old Nov 26, 2003 | 06:26 PM
SS3933's Avatar
Default New Trans Mount, New Noise?
My car developed a "thunk" at the beginning of every gear under WOT shortly after a stage II head/cam job. After much research, decided to try an energy trans mount. I understood I would get a little more vibration and noise. I installed the mount and to say the least, it's a LOT more vibration and noise. I'm getting noises at different levels of the rpm range but probably the worst thing is the exhaust. I'm running LT's into a Corsa Cat-back and it's pretty loud so the car vibrated anyway (expecially with the cam lope) but now it's like I can feel EVERYTHING going on in the engine Good news is, the thunk is gone and the drivetrain feels incredibly tighter but it is a an annoying compromise.
I'm thinking dynamat/jute around the console and seat area (already done the rear) but I'd love to hear opinions/advice as to what may help minimize some of the noise and vibrations. The car is a 2001 SS, See sig for specs on the car.
Old Nov 27, 2003 | 05:37 AM
SilverM6SS's Avatar
I have seen this a few times with the energy mounts. What i have found is the extra noise/vibration is the motor mounts. If u think ur motor mounts are fine try a regular GM replacement trans mount. See if that makes a differance.
I hope I helped.
Old Nov 27, 2003 | 09:24 AM
SS3933's Avatar
I hope I helped.
The motor mounts are still stock. If I go back with a stock trans mount then I get thunking from whatever is hitting during wot. When I pulled the stock trans mount out it wasn't ripped or torn, it appeared to be ok. It's just not strong enough to keep my driveline from banging. I need to keep this calibre of trans mount, I was just hoping to minimize some of the side effects somehow.
Old Nov 28, 2003 | 05:39 PM
Tom L. Busby's Avatar
The poly trans mount is allegedly designed for the LT1, and, in any event, is a couple of mm's too tall. It casuses the top of the trans to rub against the tunnel and transmit a huge amount of noise into the car at 2200 rpm and up.
A fix is to put one steel fender washer, with a 3/8ths inch hole I think, between the floor and the crossmember, at each of the 4 bolts that hold the trans brace to the floor. This will lower the trans back to stock height and the noise is basically gone.
A slight vibration is normal, but noise like a helicopter going by is not. The poly mount (when lowered) makes only a little vibration you can feel through your feet, rather than noise. Also I used 4 delrin fender washers instead of fender washers but the idea is the same. Delrin is brand name for a harder and more durable type of nylon. It compresses very little and is a little harder than a polyurethane washer.
