D585 coil bracket doesn't fit stock valve covers!?
I would agree that the bracket you shown that misses the hole was stamped wrong.
I started that thread, I don't believe anywhere in it does anybody say these brackets don't match the valve covers.
Yes that's what I thought... I read the whole thread to be sure. I've found that their is little to no adjustability with the 585 coils to their bracket holes and that I actually had to start the bolts with one coil particularly angled to get it to start threading. This was no doubt pulling alittle on the bracket inward.
They push the coils centered over the valve cover which after I measured a a full 1.25" lower on the valve cover. My Taylor 9mm truck wires are already long and this made it worse. One of my wires moved alittle and layed against a header and cooked it. So without a doubt you would need shorter car wires to work and this would be good with all you LS car motor guys with the stock fuel rails etc. but I have a ton of room above the valve cover and would rather them be pushed higher up. So I wrapped the burnt section of wire with a lot of electrical tape and removed the coil packs. I swapped the 585s back to the OEM brackets and will have to make them work if I want to run them. But I felt no difference between the 581 and 585 really on a stock 5.3 with 9lbs of boost. Besides cooking a wire and running 9:1 on the highway which sucked.
Pics to show how much they drop the coils.
Look at the coil mounting screws to the brackets for how much is lowered.
Same here.
