2000 camaro turbo build, 9 or 10 second build??
Old Nov 23, 2016 | 07:17 PM
mcmuscle3's Avatar
Car came from Kentucky, I have him tune all the cars I build! He does great
Old Dec 11, 2016 | 05:37 PM
mcmuscle3's Avatar
Picked up this 08 4.8 with 799 heads.
Old Dec 11, 2016 | 05:38 PM
mcmuscle3's Avatar
Anyone have some good info as to what I need to switch wiring from a gen 3 to this gen 4 motor?
Old Dec 11, 2016 | 07:11 PM
MY_2K_Z's Avatar
You need to swap the reluctor wheel on the crank for a 24t, you will need to swap the crank position sensor for the gen3 black sensor, you will need to extend the cam sensor to the front of the block and that should do it.
Old Dec 11, 2016 | 07:29 PM
mcmuscle3's Avatar
Does that mean I need to remove the crank, ?The crank sensor is on the side?
What about the knock sensors on the side
Old Dec 11, 2016 | 09:33 PM
MY_2K_Z's Avatar
Yes the crank has to be removed to replace the reluctor wheel. And the knock sensors go to the sides of the block. You will have to tap the holes for the gen 3 knock sensors though. All of this stuff is in my build thread. I had to do all this same stuff to my gen 4 ly6.
Old Dec 12, 2016 | 08:06 AM
svslow's Avatar
All these wiring/sensor changes are assuming that you will be using a factory ECU. If you get a MS3, Holley etc. you don't have to do all that.
Old Dec 13, 2016 | 08:35 PM
mcmuscle3's Avatar
Stock Ecu here.
Lingenfelter had a 24-52 tooth converter box that doesn't require switching. It sounds pricey though,
Old Dec 13, 2016 | 10:31 PM
MY_2K_Z's Avatar
I've heard a lot of bad about the converter boxes, I've heard some success stories. That's why I swapped reluctor wheels.
Old Jan 12, 2017 | 04:07 PM
mcmuscle3's Avatar
Strange coilovers
Wet sanding has began
Wet sanding nearly complete
Few minor touch ups and it will be ready for paint.
Old Jan 12, 2017 | 08:56 PM
The Cartel's Avatar
I'd remove that bump rail man. never have been a fan of them
Old Jan 16, 2017 | 06:40 PM
mcmuscle3's Avatar
Test fitting
Test fitting some stuff
Cleaned up some room for the vertical radiator.
Old Jan 17, 2017 | 12:12 PM
mcmuscle3's Avatar
Fabricated a mount for my washer fluid tank. I'm going to run hood pins and ditch the hood latch.
Old Jan 21, 2017 | 03:28 PM
mcmuscle3's Avatar
Pistons rods and crank removed. Decided to swap the 58 tooth reluctor wheel instead of buying the conversion box.
Old Apr 12, 2017 | 06:44 AM
mcmuscle3's Avatar
Turns out my 4.8 is a 5.3!! 4.8s didn't come with DOD. I painted my car and got it looking decent,
5.3l, speed inc tu1 cam, head studs-eBay, DOD delete, ls7 lifters, pushrods, .660 btr valve springs, head gaskets, 799 heads.
The new tow rig
Dual walbro 450s
Btr springs are nice!!! Bobby from ky speed hooked me up with these
Engine is in!!
Looking nice in its new home
Old Apr 12, 2017 | 09:23 AM
GaragebuiltSS's Avatar
I like this build. Paint looks good!
Old Apr 12, 2017 | 08:13 PM
The Cartel's Avatar
Great progress! looking good!
Old Apr 13, 2017 | 06:12 AM
Tuskyz28's Avatar
I'm jealous..... not of your car/turbo build but because that Cummins is on point!! Is the tow rig stock?
Old Apr 13, 2017 | 12:42 PM
  #39
mcmuscle3's Avatar
Lol, stock for now. Well it's 5" lift on 37s.
I'm downsizing to 35s shortly. And some nice wheels. It's a 2016 with 8000 miles so it's stock. Il keep it that way for another year maybe two. Then dpf /cat /egr delete and efi live.
Old Apr 26, 2017 | 08:54 PM
  #40
mcmuscle3's Avatar
Decided to protect the paint with some Avery Denison wrap. Matte white. <br/>And to give it a different look
Setting up the radiator to make room for the turbo
Test fitting some things, 4" piping with 31x12x4 intercooler
