T56 shifter location in first gen camaro with Holley mounts
Been searching for quite a while and haven't found what I'm looking for.
Anyone have photos or measurements of the shifter hole in a first gen camaro with an f-body ls1/T56 installed with Holley mounts??
Trying to get an idea how much farther back the new hole will be so I can round up patch material.
Thanks
Thanks
What year first gen? Also which t56? Camaro, magnum, cts-v? It makes a difference. I'll post pics of mine, a 67.
You will need to flip the shifter if using a magnum. Then the stock hole is almost perfect.
i can grab pictures later. If I forget just PM me. I've got a 68 using all the hooker/holley swap components and an LS1 camaro based t56. IIRC it's about 3" back from the factory 4 speed hole
I have the same car and engine and trans, but I used an Art Morrison subframe. I had to move my shifter hole back about 4 inches. With my wide aftermarket seats, I had to get rid of the stock console and make my own.
I can take a better picture, but I am running the same setup. I have the Hooker 12618HKR mounts for 67-69 Camaro and here is the hole that I had to cut in my floor. I didn't have to patch anything as the 6 speed fit around everything with plenty of room.
Got the 327/muncie out today, need to notch the crossmember for alternator clearance and then I can drop the LS1/T56 in.
On my 68 Firebird with the holley mounts and a 2000 ls1 engine/t-56, the shifter is located 16" back from the bottom of the dash.
https://ls1tech.com/forums/conversio...-location.html
