Vintage Air: Who's Installed It, And Results
I'd like to hear from the ones who have completed their restomod (enough to be driving it) with an installed Vintage Air system and how well does it work.
Temp?
Volume (cfm)?
Noise?
Temp?
Volume (cfm)?
Noise?
Just did the final tweaks on a buddies this weekend. We installed the gen IV system in a 66 chevelle and it works VERY well. Even on low it blows pretty hard and can cool off the car in minutes. On high it will get cold enough that you turn it down. We aren't in the hottest weather yet, but we are in Arizona and it's already in the upper 80's and 90's.
The issue I had was with running the a/c system trinary switch control for the cooling fan in parallel with the LS1 pcm fan control. This caused a fault code because the pcm saw the fan grounded when not being commanded. I fixed this by isolating the pcm control with a second relay and all is working perfectly.
I also have a positive experience wth the Vintage Air. My unit is older, maybe 10 years. It keeps my truck cool. In 85F or 90F ambients, I turn the fan on high and all the way down. If I drive on the highway for 30 minutes or more, I'll turn it up the thermostat target temp.
The fan is pretty loud on high. I'm guessing a newer unit might be less so.
Vent placement is a factor. Whether it blows on your or not. I'd say point that at yourself or the passengers. I have one pointed in to the cab, but not at any person and that doesn't add as much.
This is kind of a loaded question, because people's opinions will vary. I think the A/C in my '33 works pretty well, where as my gf thinks it works way too good! The most important thing about any A/C though is being able to keep the cold air in and the hot air out. The best system in the world wont appear to work very good if there's a lot of hot air coming in. This is the number one reason new cars seem like the air works better in them, they are insulated and sealed way better than you can seal an old car. My '33 works better around town than on the highway because of this. There is just no real good way to seal the doors on it to keep all the hot air out.
Also, as for the Sanden or factory compressor, either use the Sanden or a fixed displacement one. I tried the variable compressor with very limited success. It works, but not at near the efficiency of the one I have with the compressor VA supplied.
I just received my kit and those vents seam a little cheesy.
I am going to use OEM A/C car vents vs. Vintage Air parts. I like the OEM look.
Do you mean you used the Vintage Air vents for a non AC car? Or are those stock 66-67 air vents? I'm pulling the trigger on a system this week but am unsure of how to do the lower dash vents. My car is a 65 so not sure if the dash is alot different than 66-67. I don't like the under dash add-on vents Vintage sells with their kits. Want a more stock look.
