Maybe FiTech learned LS engines matter? :)
#61
I would think that cutting fuel while under boost could hurt the engine because of lean cylinders. Or I would guess if fuel was totally cut it would be fine.
Looks like I better buy my spark plugs in bulk while tuning and learning.Anyway I'm looking forward to getting the manifold on so I can make the motor mounts and then the rest of the turbo install.
Aleck
Aleck
#62
Fitech install still on pause for me
Im very sorry for my untimely slow progress... and delayed response to inquiries as to my progress.
Due to time of year (gearing up for school, kids hm, etc), I have been unable to make time for myself to finish my pushrod length decision. Once that is completed and valve covers on, it's literally time to install FiTech intake etc and start plugging things in.
Aug 18 is back-to-school date... I'm ASSuming that the following Monday will be a full day work on completing pushrod task -
Tough to have such a full-on effort vehicle just sit in the dark under cover knowing how close it is to completion. I expect I'll have to farm a question or 3 to the masses seeking suggestions/advice/share-experiences... soon...!
#63
Aleck
Aleck
If you've cut fuel to a cylinder, there is no fuel...so it is impossible for there to be a lean condition, as no combustion is even taking place because there is no fuel.
Cutting spark only...allows raw fuel to get dumped through the engine, into a hot exhaust, also potentially soaking the plug. So cutting spark is a less desirable option in a lot of cases
#64
Still in box and my first warranty claim
Well I got my Fitech Ultimate LS system 70013 same as the op. Opened the sealed box like a kid on Christmas morning. Lo and behold as I unpack the undamaged box I find that the main harness connector to the ECM is crushed. So am I.
Was like I found out there is no Santa Claus.
Nothing else inside the box or the box itself shows any sign of damage. So my guess is it was packaged this way. The plug on the harness was smashed so it had to be crushed between two things.
The good news is Fitech took care of the problem FAST. I got a new harness delivered to my door in less than a week. Consider that I live in Ontario Canada and that the part had to go thru customs.
I'm posting this to tell others about Fitech's excellent customer service. I was never given the run around. All that was asked of me was to send some pictures of the damage. I was treated like I am their biggest buyer.
Thank You Fitech for Great Fast customer service.
This is not a paid announcement .LOL.
Aleck
Aleck
#65
That's good to hear.
I just got my FItech self learning LS harness yesterday 70050 and I'm excited to put it on at some time either fall or winter. I'm also doing a NNBS intake and 92mm WARR TB so hopefully it has no issues tuning all that.
#68
That's MISTER MODERATOR
I was actually linked to this thread from a post in a thread I started over at Chevelles.
I received the 70051 stand alone system yesterday. It's very nice, complete and nothing damaged. It was in stock at Summit.
I don't think anybody in this thread mentioned it, this is a speed density system, no MAF.
The injector harnesses are for LS1 injectors. If you're using EV6 injectors, you'll need adapters or need to change the plugs.
The harness sections are too long, I'm sure most users will shorten everything up.
My twist is I'm installing this on my 496 big block, which has been outfitted with LS1 sensors.
I have a bunch of other things to do so it'll be a while before I actually fire this system up.
#69
I also don't think it was mentioned, the ECM will work with 24x or 58x crank sensors and 1x or 4x cam sensors. And you can mix them up. Example: 24x crank sensor and 4x cam sensor. It will work.
The harness has a LS1 cam sensor plug and an adapter harness with a LS3 cam sensor plug to hit a timing cover plug.
It has a LS1 knock sensor plug and an adapter harness that plugs into it for side mounted LS3 knock sensors. I suppose you can tell the system which knock sensor you're using.
#70
The LS1 (gen3) cam sensor is 12v while the LS3 (gen4) cam sensor is 5v. How does the adapter harness resolve that? On other EFI systems the cam wires need to be repinned.
Andrew
Andrew
#71
If Fitech did their homework, they prob swapped the wires in the adapt. harness, be good to ck-I have heard of people using the +12 on the 5v ref, but no first hand knowledge of it.
Thanks Paul for the pic, it looks like you do get the trans plug in the kit, they made it sound like you needed to source a harness.
Now, someone needs a running car to test this, I am not near ready, lol
#72
No doubt the adapter harness locates the wires correctly in the LS3 plug.
#74
I'm using a front cover sensor and giving it 12v.
#79
My harness is installed into my car. A few annoying things:
Most harnesses are way long. The IAC plug's cable was like four feet out from the main harness section. I'm hoping I can tell the ECM to swap o2 signals.
I installed my harness through the firewall next to the steering column. This places the passenger side o2 plug right there-and the driver's side o2 plug long enough to hit the passenger door. Opposite where I'd like them.
Just about every wire in the harness got re-worked by me. Solder, tape, shrink-all while standing in the engine bay. I need a drink!
Looking at other systems on the market, they all seem to include a wiring schematic in their instructions. Not so with FiTech. I hope they offer it if asked.
