Victor Jr. intake ETP 225s big bore 383 dyno results!!!
Owner Chris AKA NosboySS
383 iron block big bore, offset ground crank, yadda yadda.
ETP 225 CC heads
CR ~11.4:1
Victor Jr intake 104mm TB light port job on the runners.
cam high 24x low 25x exhaust cam on a 112 LSA
1-7/8s kooks
TH350 locked up, 12 bolt.
98 Transam Speed density, of course, tune by yours truly
heres the graph.
Made more than all of us expected but I won, becuase I was the closest!
Nick I don't know what you were thinking (hoping for) but I was guessing 505-510, 470 tq, verbalizing 475-480hp to keep from disappointing some people if it did not hit the high mark! But I always told Chris ,...."there is NO reason it should not hit the 500 mark if done correctly!"
Now for the N20!
Corrected to boot! NICE!
Does the SD tune make it easier to tune and/or get more power out of a motor than a MAF tune????
BTW, CONGRATS!!!
BTW, CONGRATS!!!
There is pretty much no economical way a maf can be run on this car, if you saw the intake, and where it was you would understand...... it was the only alternative. Even if something were to be fabricated to some form of intake piping to maf it would be a restriction, so yes, the SD tune allowed for this setup to reach it's full potential. However it is more involved in tuning the car, a lot more time consuming
but well worth it. Trending Topics
Pm me sucka
Question,,,,,will 100 octane help at all at the track or will the tune have to change to gain anything?? With 11.4 comp I hear it wont help and it will help. Just some opinions will help at this point
We would have to add some timing in there to make more power with 100 octane, we are already at 26-27, I would say its a minimal gain, probably not worth that extra 5 hp to pay 6 bucks a gallon for. now with nitrous, thats a different story. On my car I run about 28 degrees of timing nitrous I like to run 104 with 150 kick that actually makes 225ish.
