98 z28 part out to make drag car
Heres whats left. If you dont see it listed, I dont have it.
Car was a perfect silver 98 z28 w/ dark grey interior. everything is OBO.
Exterior
*Z28 hood. Excellent condition. $150
*silver Z28 wheels w/ tires that have about 40% tread left. $250
*rear bumper support $30
Interior
*center console top and bottom. ash tray lid broke. carbon fiber around cig lighter $150
*gauge cluster w/ 88,xxx miles on it $50
*firewall pad $30
*complete set of seat belts front and rear $100
*airbags, driver and pass side w/ module $100
*under dash plastic $20
*fold down divider for hatch$50
*well carpet for hardtop car. $30
Under hood
*cruise control,tcs assembly with all cables. $50
*washer fluid resivoir and pump $30
*lower spoiler for radiator $30
*hood gas shocks w/ brackets $50
*hood hinges $40
*hood latch bear claw w/ cable and interior kick panel handle $20
*Hood latch/handle under hood $25
*hood stricker under hood $25
*metal brace bolts to radiator support, holds latch $35
*metal brace, bolts to hood latch brace and plastic bumper support $25
*air pump assembly $25
*lower airbox $25
*radiator w/ cap and hoses $100
Steering, Suspension, chassis, drivetrain
*10 bolt with rear brakes, brake lines, 4-channel, 4channel wiring harness. All you have to do is connect 2 brake lines and plug in harness. Complete! $250
*steering rack with power steering lines $150
*stock panhard support rod $25
*stock rear v8 springs with rubber mounts $50
*stock steel driveshaft $50
*stock front sway bar w/ brackets $25
*stock rear sway bar w/ brackets $25
*trans crossmember for auto $50
*front springs $40
*rear shocks $25
Brakes
*E-brake handle assembly, leather handle and all 3 e-brake lines $125
*master cylinder $50
*brake booster $50
*all hard brake lines and flex stainless lines going to abs module "block" $50
*ABS module "block" with bracket $50
Stereo
*monsoon amp w/ bracket $65
*hatch speakers $30
*speaker plastic baskets for doors $15
*tape player/radio head unit $25
*aftermarket 6-disc CD chager with wiring harness for stock radio $75
Fuel system
*complete steel tank assembly w/ pump, float, fuel lever senser, wiring harness, some lines, straps, hardware $150
*EVAP system $25
Misc. parts off another z28
*a4 top section of console. hairline crack on passenger side. bare. no selector or ash tray lid. $40
*t-top cap that screws to roof to hold top of b-pillar plastic. $20 pair
*door sills $30 pair
*red hood hinges $ 40 pair
*ABS module "block" bracket $20
*Hood gas shock brackets that bolt under hood $30 pair
*Red hood latch striker that bolts to bottom of hood $25
*Purple radiator support brace that holds hood bear claw $35
*black support brace that bolts to radiator support brace and plastic nose support $25
*Red driver side mirror housing. needs to be painted $20
*silver passenger side mirror housing. needs to be painted $20
Exterior
Interior
*firewall pad $30
Under hood
*hood hinges $40
*lower airbox $25
*front springs $40
*rear shocks $25
Brakes
*brake booster $50
Stereo
*hatch speakers $30
Fuel system
*EVAP system $25
*lower airbox $25
*lower airbox $25
Bill
