(2) Complete TWIN Kit Packages Available ~Amazing Package Pricing!~
Category: Engine - Power Adders
Price: $4750
Location (State): MI
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
I only have (1) of each so order yours while you can!
~~~~These packages are ADDITIONAL Savings beyond the current sale running on the base twin kits~~~~
Package 1: $4750 Shipped
(normally $5624) *$874 off*
-Includes-
*Our new V2 Stainless Steel, Vbanded, extra thick .120 wall Manifolds that retain the OEM Alternator location
* 2.5” extra thick .120 wall Stainless Up-Pipes, V-banded allow for easier installation with 44-46mm V-banded Wastegate ports and primary O2 sensor bungs. All piping stays ABOVE the oem sway bar!
* Pair of full 3" Stainless 2-piece downpipes routed through a Turbo Style K-member will supply the exhaust flow needed for 1500hp. Downpipes do NOT come with the recirculation ports as shown in the picture. Wastegates will dump.
*Standard 3.5" Thick Core intercooler with direct bolt on bracket, dual inlets and single outlet.
*Fully Polished 2.5" cold side piping from turbos to intercooler and 3.5" cold side piping from Intercooler to Throttle Body with a pair of 50mm BOV flanges.
*All necessary couplers and clamps included in this kit. Entire hotside consists of all v-band connections
*Stainless Steel Hex Head Bolt/Hardware Kit included!
*(2) Precision PT6266cea Billet Wheel, Journal bearing T4 Turbochargers
*(2) Precision PW46 Wastegates
*(2) XS-Power 50mm BOV's in Black
*(2) Black T4 Turbo Blankets
Package 2: $6250 Shipped
(normally $7174) *$924 off*
-Includes-
*UPGRADED BELL 4.5" Thick Core intercooler with direct bolt on bracket, dual inlets and single outlet.
*(2) Precision PT6766cea Billet Wheel, Journal bearing T4 Turbochargers
To view the base form of these kits on our website for full information, check out this link:
[B][SIZE="3"]Complete Kit:http://shop.huronspeedproducts.com/H...it-hspv2tt.htm
*Kit requires: Stood up radiator with coolant hoses and fans to clear piping/turbo. A/C removal. Turbo Style K-member required if wanting to run the downpipes out the back. Can dump the downpipes up front with use of a factory K-member. Requires Oil lines as well to complete.
*Kit built around a pair of standard T4 Turbochargers with 3" V-band discharges such as: Turbonetics Hurricane Series (TC66-TC78), Turbonetics T-series (7575, 7875), Precision T4 w/ S trim or H trim covers (6262s through 7675s) Comp CT4s or CT43's with T4 housings (6062s through 8079s) and many many more.
*Kit RETAINS: OEM Alternator location, OEM Front Sway bar, OEM Power steering, OEM ABS.
Few videos for your enjoyment as well!
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
