Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
<<SOLD>>Comp ls camashaft, spring kit, pushrods NEW PRICE!! 550.00 SHIPPED!!!
Old 12-22-2015, 12:39 AM
tjs114's Avatar
Category: Engine - Power Adders
Price: $550
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): TX
Item Condition: Brand New
LS Engine?: Fits LS Engine
I'm interested in just the valve springs.
Old 12-22-2015, 09:58 AM
parks450's Avatar
Pushrods and springs price? Cam is a tad bigger than I want
Old 12-22-2015, 10:23 AM
98camarozzz's Avatar
Originally Posted by CJ-Z
400 shipped for cam & pushrods
Interested, these still for sale?
Old 12-22-2015, 03:59 PM
ncmcamaro's Avatar
Is the cam a single bolt or three bolt cam??
Old 12-22-2015, 10:37 PM
wooddaniel's Avatar
What was the cam originally intended for? Is it 3 bolt or single?
Old 12-22-2015, 10:50 PM
Blk92notch's Avatar
Privete message sent
Old 12-23-2015, 04:27 PM
CJ-Z's Avatar
still available
Old 12-23-2015, 04:28 PM
CJ-Z's Avatar
ls3 --3 bolt
Old 12-23-2015, 04:37 PM
CJ-Z's Avatar
Default More cam info
Texas Speed LS3 231/236 .644"/613" Camshaft
base price $399.99
item# 25-231236 Previous Up Next"
|Share
TSP's all new line of LS3 camshafts are a result of months of engine dyno camshaft development using our state of the art Superflow 902 engine dyno. Using a brand new LS3 crate engine we started from scratch to build the most power LS3 camshafts available in the country.
The 231/236 camshaft is a great larger duration camshaft for power applications from 2200rpm+. This camshaft is designed to make more power than the stock camshaft above 2200rpm even with it's larger duration! The 231/236 camshaft uses a tighter lobe separation and extra advance to create awesome across the board power. The result of these changes is a large duration camshaft that makes over 80 peak hp gains with a radical idle. LS3 computers can easily be tuned to drive great with this camshaft with some bucking bellow 1500 rpm. M6 cars or automatic cars with stall converter 2500rpm or larger required. We recommend this camshaft for LS3 or LS2 engines using L92/LS3 rectangle port cylinder heads!
Aggressive intake lobe requires the use of a Precision Race Components EHT Spring Kit!
Specs:
231/236 .644"/613" 111 LSA *camshaft is also available in wider LSA
**The factory LS3 camshaft uses a single-bolt cam design, which means one bolt holds the upper timing sprocket on the camshaft. For LS3 vehicles, you can either go back in with a single-bolt camshaft or convert to the three-bolt camshaft design that the 1997-2006 LS-based vehicles use. The three-bolt conversion kit will supply the correct 4x upper timing gear to supply the correct camshaft position signal, as well as the ARP camshaft bolt kit that will supply the three required bolts. We also offer the converison kit with a complete, upgraded timing set for those wanting to replace the entire set.*
Old 12-27-2015, 07:35 PM
GremlinTheGoat's Avatar
How much for cam and springs?
Old 12-27-2015, 10:58 PM
wooddaniel's Avatar
OP, can you text me some pictures with your name next to the part on a card? Paypal ready. This will fit an L76 G8GT motor correct? I'm assuming so if it's an LS3 cam.
# is 352-870-one172
Old 12-31-2015, 11:53 PM
  #32
wooddaniel's Avatar
PM Sent
Old 01-02-2016, 11:41 AM
  #33
CJ-Z's Avatar
Pm sent
Old 01-04-2016, 05:56 PM
  #34
wooddaniel's Avatar
Replied
Old 01-05-2016, 05:33 PM
  #35
wooddaniel's Avatar
Paypal sent
Quick Reply: <<SOLD>>Comp ls camashaft, spring kit, pushrods NEW PRICE!! 550.00 SHIPPED!!!
