1986 Ford LTD Turbo Sleeper great daily
Year: 1986
Make: Ford
Model: Aerostar
Price: $13500
Mileage: 1
Location (State): AZ
Color: Beige
LS Engine?: Car has LS engine
Holley efi
120 lb trickflow injectors
AEM 380lph pump/walbro 255
Rod piston ls6 shortblock built by WFO in AZ
Block honed to 3.905
Stock crank
Manley Platinum Series Piston Set (forged, 3.905) 592107C-8 - http://www.summitracing.com/parts/man-592107c-8
Manley Piston Ring Set 46107ST-08
Eagle H-Beam Connecting Rod Set (forged, 6.125 w ARP bolts) CRS-6125-03D - http://www.summitracing.com/parts/esp-crs6125o3d
ATI balancer
799 heads BRT springs/pushrods/cam
Moroso 20143 oil pan
Turbo kit started out as ON3 kit
Billet s476/87
Garret 4.5" air to air
3.5" downpipe
I have a full exhaust for car with a vacuum actuated cutout, doesnt fit with new bigger driveshaft, driveshaft safety loop just needs to be moved forward for exhaust to fit
TH400 rebuilt not long ago
Circle D converter 34 sprag, deep pan, 300m input shaft, BTE valvebody/transbrake
ATI shifter with transbrake/2step button on handle
93 cobra rear brakes/booster/master cylinder/line lock/gt mustang fronts
AJE front k member/team z control arms/strange single adjustable strut/coil over
Rear end is welded/35 spline/spool/viking dual adjustable coil overs/springs/ 3.5" alum driveshaft/chromolly yoke/chromolly pinion flange/3.27 gears/Team Z ARB
