Vrx5 Cam kit
I thought about it for the wife's Aero or a backup for the TBSS. I think our TBSS are a little heavy for this cam at least for the way we use ours. I have an Attitude V3 in the SS and honestly if I go into it, I'll go slightly smaller even though I do like the way it rolls. I'm in the middle of a bad lifter problem. I hope my V3 isn't hurt. I'll probably have it apart tomorrow to see.
Was already in work on the PCM oil pan fix. Always something.
Anyway if you roll hard in your TBSS and have a decent stall you could roll with this one.
Bump for my 2 cents.
I thought there was a difference in the ls1/6 and ls2 cams....or is that only with factory cams concerning cam sensor location? I'm looking for a big cam for my 4K stalled c5...
I had to search a little but this is the answer I found on the subject answered by jon from Texas speed.
You would have to put the LS2 timing chain and front cover on as well and get an extension harness for the cam sensor. The cam sensor on a LS1 is on the top of the block in the BACK by the oil pressure sending unit. The LS2 cam sensor is in the front cover. Hints why you need the extension harness. We have all the parts if you need it.
