Notices
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Procharged 2000 Camaro SS
Old 05-15-2017, 09:17 PM
DominoEffect383's Avatar
Default Procharged 2000 Camaro SS
Year: 2000
Make: Chevrolet
Model: Camaro
Price: $17000
Mileage: 52000
Location (State): FL
Color: Red
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Engine (Less Than 5,000 miles):
• 383ci
• 11:1 compression
• LS1 Block w/3.905 bore
• JE Flat top pistons w/4cc valve relieves
• Manley 6.125 H-Beam connection rods
• Total seal zero gap second ring package
• Callies 4" stroke crankshaft
• Melling high volume oil Pump
• Brute Speed Blower Cam (Dur @ .050 232 int 240 exh/ .595 int .608 exh/ Lobe Sep 115.0)
• New GM Timing Chain and gears
• LPE Ported Cylinder Heads (2.02/1.60 valve with TI retainers and dual Valve springs)
• 7.400 Hardened Push Rods
• Crane Cams hydrolic roller lifter
• GM gaskets
• ARP Head & Main studs
• Drilled and pinned crank shaft for ATI Damper
• LS6 Intake
• LS2 Water Pump
• Be-Cool Aluminum Racing Radiator (PN:60028)
• 9 inch Spal puller Fan
• 16 inch Spal puller fan
• 160 Amp High Output Alternator
Exhaust:
• Pacesetter 1 ¾" long tube headers
• Off-road y-pipe
• Flowmaster catback
Fuel System (Less than 500 Miles):
• Lonnies Double Pumper return style system
• -8 Supply & -6 Return lines, fuel rails, regulator, hobbs switch
• Twin in-tank Walbro 255s
• Siemens EV1 Long Style 80lb injectors
• Alky Control Meth Kit
SuperCharger
• Rebuilt D1SC with less than 500 miles
• Twin 3.5 intercoolers
• ATI Red Race Valve
• Aster Bracket
• 3.4" blower Pulley, 7.65 Crank Pulley
Transmission (Less than 1,500 Miles) :
• 4L80e
• Trans Go HD2 Shift Kit
• New Clutches and seals
• Kelvar wide Band
• B&M Trans Cooler
• JW 2800 Stall Convertor
• Custom Steel Drive Shaft
Rear End (Less than 1,500 Miles):
• Stock 10 bolt 3.08 gear
Suspension/ Misc.
• Edelbrock lower Control Arms
• Edelbrock Torque Arm
• Sub Frame connectors (forgot the brand)
• Strut tower brace
• Russel Stainless Brake line for front and rear
• Corvette C5 brakes
• Power slot rotors
Clean Florida title two owner car. Can provide carfax if needed. Best pull the car made was 703rwhp @ 5400rpm and that was before the big fuel system was put on. Car is currently tuned for 630rwhp. Unfortunately I never have the time to drive it so I'm considering selling. this car sits on a battery tender in the garage, never out side. I have receipts for almost every single modification done to the car. The mileage on the body is 51,250.
This is very clean well built 4th gen. Yes I know it needs a better rear end for the current power, but aside from the rear end its pretty complete.
Im open to offers.
Call or text: 386-366-4470 Bryar
Attached Thumbnails Procharged 2000 Camaro SS-camaro.jpg   Procharged 2000 Camaro SS-img_0988.jpg   Procharged 2000 Camaro SS-img_2486.jpg   Procharged 2000 Camaro SS-img_1003.jpg   Procharged 2000 Camaro SS-img_2560.jpg
Procharged 2000 Camaro SS-img_2561-copy.jpg   Procharged 2000 Camaro SS-img_4534.jpg   Procharged 2000 Camaro SS-img_4513.jpg   Procharged 2000 Camaro SS-img_4501.jpg   Procharged 2000 Camaro SS-img_2803.jpg
Old 05-17-2017, 07:04 PM
Default bump
bumpp
Old 05-19-2017, 02:58 PM
bump!
Old 05-23-2017, 07:24 PM
Default ....
Bump!!
Old 09-10-2017, 05:34 PM
Bump!!
Old 11-28-2017, 02:08 PM
Default Bump!!!
Bump!!!
Old 12-04-2017, 11:47 PM
LouisianaCam's Avatar
Bump. Very nice car!!
Old 05-26-2018, 10:59 AM
Default Bump!
bump!
Old 05-27-2018, 11:29 PM
Game ova's Avatar
I can't afford the car, but I can give a free bump for a nice 4th gen.
Old 07-11-2018, 06:55 PM
Default Price lowered
Priced lowered to 14k
Old 07-11-2018, 08:27 PM
tnmotown's Avatar
Why are all the decent cars on the east coast!?!? Lol. GLWS man
Quick Reply: Procharged 2000 Camaro SS
