Category: Accessories
Price: $3500
Location (State): IN
Item Condition: Used
LS Engine?: Fits LS Engine
Up for sale is a 4l80e that was built with jakes lvl 5 parts back in 2013. Order the parts then had trans assembled. Was built for full manual. But i switched to full auto and i took the trans to RPM in anderson indiana were they went thru it replace seals and gaskets and had to take out the trans brake because it wouldnt work with auto set up. Trans has everything that jakes offered in lvl 5 minus the upgraded bell housing as it wasnt a opinion back then. I pick trans up from rpm nov 19 2015. It has 50 miles on it and 10 dyno pulls.U can go to face book look at mike norris motorsports to c dyno just in the last month. Its the silver nova. Converter is a billit triple disc lock up converter from jakes also. 3500 stall.Controller is a us shift quick 1 box. Trans is in car now if u want to look at it.Trans only has 50 miles on it total.Have about 6500 in trans. Going different route. 3500. For all. I will split the cost if u want rpm to inspect it. The transmission has a Billet Input shaft, Billet main shaft, 36 element super sprag , billet clutch hub. Trans is built to handle any thing u can throw at it. Located in kokomo,in 46901.
