Notices
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Feeler: 2011 Camaro SS Project
Old 11-01-2017, 06:04 PM
corpserodeo666's Avatar
Default Feeler: 2011 Camaro SS Project
Year: 2011
Make: Chevrolet
Model: Camaro
Price: $45000
Mileage: 7700
Location (State): IL
Color: Black
LS Engine?: Car has LS engine
I am just trying to see if there is interest for my almost brand new 2011 Camaro 2SS project. Its setup to be a street car, with a 500 shot on tap. The whole plan for this car is to run a low 8 high 7 and drive it home. I kept it pretty much to stock as possible on the interior. Please see detailed information below.
The car itself has about 7700 miles on the body and all the additional parts are pretty close to brand new or brand new. The car just got wrapped in 3M Satin White Vanilla and ceramic coated, the cars original paint color is black.
Details:
-Full leather interior with rear seat delete.
-6 Point weld in chromoly cage with swingouts
-Midwest Chassis Parachute mount kit installed. With Stroud chute
-VFN fiberglass hood
-Weld S71 beadlock Wheels 18x4 front and 15x10 in the rear with brand new 30" DOT Slicks
-Upgraded gears with Detroit locker 4.11 gears in the rear with 1400HP DSS Axels (I also have a 9” conversion rear end that I might be keeping with drive shaft).
-PFADT suspension components and solid motor mounts
-QA1 adjustable front coilovers in front.
-Carlyle 15" conversion with Strange rear coils.
-All lights work (including factory HID) and all interior components
-Holley Dominator HP with upgraded 7" dash screen.
Long Block Break Down:
-GMPP LSx block punched to a 427ci 12.5:1 Compression
-K1 Technologies Crankshaft Shaftech Balance Crankshaft to 1850 BW, Counterweights, Magna Flux Insp, Check TIR
-Diamond Custom Dome Piston, Int Mill Maxi-Lite, Offset Pins, Pin
Fit, Dbl Pin Oilers, Inboard Forging, H-13 Piston Pin .927D,
Support Rails
-Callies Ultra H-Beam Rod SBC 6.000 2.100
-Clevite H-Series Rod Bearing - Standard Size, TM-77, Chevy,
Small Block
-Clevite H-Series Main Bearings
-Cloyes Hex-A-Just Timing Set - Hex-A-Just, Single Roller, Billet
-Steel Sprockets, Chevy, 6.0L, Set
-Melling Performance Oil Pump - Standard-Volume, Chevy,
4.8/5.3/5.7/6.0L, Each
-ARP Cam Bolt Kit - High Performance, Black Oxide, M8, Chevy,
5.7L, LS1,Setof3
-ARP Balancer Bolt Kit - Chromemoly, Black Oxide, 12-Point,
Chevy, 4.8, 5.3, 6.0L, LS1, LS6, Each
-Fel-Pro Conversion Set Gasket - Chevy, 4.8, 5.3, 5.7, 6.0L, Set
-Total Seal Piston Rings
-COMP Cams Custom Ground Camshaft Core - Camshaft,
Custom Grind, Race Roller Tappet, Chevy, Small Block, LS1,
-Durabond Cam Bearings - LSX
-Crower Shaft Mount Rocker Arms
-GMPP-DR CNC Ported heads 6-bolt heads
-PAC Racing Springs Dual Spring 400 Series Retainer - Titanium
-LS retainer for PAC-1530, 1335 Valve Springs. Lock angle: mini 8
-PAC Valve Springs - DUAL SPRING 1.300 OD, 1.800, .800 LIFT
-PAC Racing Springs Steel Spring Seats (0.060 Thickness)
-PAC Racing Springs Steel Valve Locks - Mini 8 degree - Radius
-Groove - +0.050 Install Height
-Isky Red Zone Solid Mechanical Link Bar Lifters – Needleless
-Bronze Bushings, EZ Max
-Chevrolet Performance Valley Cover Gasket
-Holley Hiram Setup with dual FAST 4500s
-Nitrous Outlet Hi-Ram kit with two stages of nitrous, setup to take up to a 700 shot.
Exahust:
-American Racing 1 7/8 headers
-Custom dual 4" exhaust from header back (i have more pictures of this PM me for details)
Fuel System-
- 160Lb/hr Holley Injectors.
- Aeromotive Eliminator stealth system
- Stainless braided lines, 100 micron filter, etc..
Transmission is also new and details are below:
DRC Stage 4:
- Race prepped OEM case, bead blasted, clearanced, deburred and painted black
- Clean neutral reverse manual with trasnbrake.
- Cast aluminum pan
- Needle bearing through out
- aluminum direct drum with 34 element sprag
- 300mm input shaft
- J.W. Ultrabell
- PTC billet aluminum converter stall speed set at 4400
- TCI Outlaw Shifter
Please no tire kickers and no low ball offers. I am flexible on price but do not need to get rid of it. If you require more information feel free to PM me. Everything on the car is pretty much new or less than a few hundred miles on it. But if you do need more information from me please PM me for details, as I am sure I missed a few things. The price is negotiable. The car runs and the wrap is done (the pictures below are a month or so old)
Old 11-06-2017, 07:55 AM
PMs replied.
Thanks,
Old 11-13-2017, 07:56 AM
Bump..
Old 06-01-2018, 12:53 AM
I updated the post. The car runs and just needs a tune with a few minor things. I have more pictures and some videos of it. Please PM me if you are interested.
Old 06-03-2018, 04:38 PM
1 fast ride's Avatar
Interested in trades
Old 06-03-2018, 05:01 PM
Send me PM. What you got?
Old 06-18-2018, 10:58 AM
PMs replied. Thanks.
Old 06-28-2018, 09:29 AM
PMs replied. Thank you.
Old 07-20-2018, 12:16 AM
Bump..
Old 07-29-2018, 02:50 PM
Bump..
Old 09-16-2018, 09:59 PM
bump.. photos updated.
Quick Reply: Feeler: 2011 Camaro SS Project
