1999 BGC Trans Am Cammed
Year: 1999
Make: Pontiac
Model: Trans Am
Price: $7000
Mileage: 90000
Location (State): FL
Color: Green
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Please send a PM if interested.
The car has some modifications, mostly done by the previous owner:
Hooker Full Exhaust
QTP E-Cutout (Does not work, needs to be replaced)
Comp "Custom" cam (231 237 .589 .595 112LSA)
Vigilante 3600 Stall
B&M Trans Cooler
Ls1 Underdrive pulley/Harmonic Balancer
Ls6 Intake
SLP LID
Mac Filter
Tuned @ Speed Inc.
Suspension:
Eibach Lowering Springs
Bilstein Struts/shocks/mounts
Trac-Tek Tubular *Weld in* Subframes
Appearance:
Window Tint (20% rear, 35% front)
Chrome 17x9 Z06's wheels
VFN Ws6 Hood
Autometer Trans Temp Gauge
XenonDepot 10000K HID'S
Other
SLP Line-lock
Power Slot Rotors
HAWK pads
BMR Driveshaft Loop
New Parts installed by me:
MSD spark plug wires
Both O2 sensors (Bosch 13111)
New rear tires, front ones have around 500 Miles on them
New Spark plugs (NGK TR55)
Driver side window motor
Fuel pump
Fuel filter
Coolant sensor
Battery was replaced about 10k miles ago
New Windshield wipers
The bad:
The clear coat is peeling in some areas due to sun exposure.
AC does not work, probably needs a charge.
Another issue is that the car has no interior carpet or back seat. I took them out because I planned to put mini-tubs and a cage but I lost interest in racing after I got married and became a father.
The display on the radio/CD player that shows the radio station number doesn't show anything. Some of the rear speakers that I removed when I was working on the car are missing. Although the radio and CD player play music just fine. I did not cut any of the wires, so if you plug in speakers they should work.
It needs a seat belt guide for the driver's seat (I bought it this way and has never bothered me).
I have described this car as best as I could. But I'm sure if you look hard enough you will find small issues here and there that are typical of F-bodies of this age (cracked dash and door panel). I have taken pictures of all of the issues that I have found. But as I said, the car runs and sounds beautiful, very strong.
Along with the car, you'll get the old cam, back seat (only the top back) and other miscellaneous parts. Will also throw in a custom car cover.
