Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Iron block LS1 short block
Old 04-19-2018, 05:25 PM
BigEd_72455's Avatar
Default Iron block LS1 short block
Price: $1200
Location (State): AR
Item Condition: Used
LS Engine?: Fits LS Engine
Genuine GM oil pump
NEW Genuine GM oil galley plug
NEW 24X crank sensor
NEW LS2 cam sensor
NEW front timing cover
Gen IV block hot tanked and cleaned
torque plate honed
Diamond Power 3.898 press pin pistons
Gen III polished 24x crank with extended rear (99-00 models)
Press pin Gen IV rods
new woodruff key in crank
DOD/VVT Delete
ICT Billet lifter valley plate with new gasket.
Enginetech piston rings, rod and main bearings
Clevite P series new cam bearings
oil pump came off a 6.0 I had barely run (new when installed to the 6.0)
NEW Elgin Engineering E1841P camshaft (specs below)
Intake Valve Lift: .595"
Exhaust Valve Lift: .595"
Advertised Intake Duration: 296°
Advertised Exhaust Duration: 299°
Intake Duration @ .050": 238°
Exhaust Duration @ .050": 242°
Lobe Separation: 112°
located @ 72455 zip code
NO DELIVERY OR SHIPPING
CASH ONLY! will do some trading for cathedral port Edelbrock Victor jr carb intake and MSD 6014 box.
This has never been run. I had it up to along block and have since removed some parts and sold them. It cranked over with 50 psi oil pressure. I was using 16 volts from my golf cart though.... I did pre-oil the motor before cranking it over as well.
Attached Thumbnails Iron block LS1 short block-img_0097.jpg   Iron block LS1 short block-img_0098.jpg   Iron block LS1 short block-img_0125.jpg   Iron block LS1 short block-img_0131.jpg   Iron block LS1 short block-img_0132.jpg
Iron block LS1 short block-img_0133.jpg   Iron block LS1 short block-img_0134.jpg   Iron block LS1 short block-img_0135.jpg   Iron block LS1 short block-img_0137.jpg   Iron block LS1 short block-img_0175.jpg
Old 04-27-2020, 01:12 AM
Sold!
Quick Reply: Iron block LS1 short block
