Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
2016 GM Performance LS376 525HP Crate Motor
Old 03-16-2018, 08:34 PM
LS Powered Courier's Avatar
Default 2016 GM Performance LS376 525HP Crate Motor
Price: $4900
Location (State): IN
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
2016 GM Performance LS376 525HP Crate Motor. As you can see by the pictures this motor is extremely clean inside and out.
I have no idea how many miles this motor has on it, but the cylinders and piston skirts indicate that it is a very low mileage motor.
The motor is completely disassembled. A spun rod bearing was found. A replacement crank and rod are provided to the buyer with purchase. The crank will need polished and it may require a new reluctor wheel (see picture). The motor will need to be align honed before reassembly. It will need rod and main bearings, head bolts and a crank pulley bolt. It may need rings and a few gaskets and some miscellaneous bolts.
GM Performance LS376 525HP crate motors sell for $8,498.00 new. I'm asking $4,900.00 for this one and there is no core charge either.
You can reach me by phone or text message. I reply to real buyers asking real questions. I will not reply to messages that ask, "Is item still available." I will not reply to copy and paste messages.
Additional Information on a GM Performance LS376 525HP crate motor.
Part Number: 19369338
Engine Type: LS-Series Gen-IV Small-Block V-8
Displacement (cu. in.): 376 (6.2L)
Bore x Stroke (in.): 4.065 x 3.622 (103.25 x 92 mm)
Block (P/N 12623967): Cast aluminum with six-bolt, cross-bolted main caps
Crankshaft (P/N 12685659): Nodular iron
Connecting Rods (P/N 12607475): Powdered metal
Pistons (P/N 19207287): Hypereutectic aluminum
Camshaft Type (P/N 88958770): Hydraulic roller
Valve Lift (in.): 0.525 intake / 0.525 exhaust
Camshaft Duration (@0.050 in.): 226° intake / 236° exhaust
Cylinder Heads (P/N 12629063): Aluminum L92-style port; "as cast" with 68-cc chambers
Valve Size (in.): 2.165 intake / 1.590 exhaust
Compression ratio: 10.7:1
Rocker Arms (P/N 12569167 int): Investment-cast, roll trunnion
Rocker Arms (P/N 10214664 exh): Investment-cast, roll trunnion
Rocker Arm Ratio: 1.7:1
Recommended Fuel: Premium pump
Maximum Recommended rpm: 6600
Reluctor Wheel: 58X
Balanced: Internal
Attached Thumbnails 2016 GM Performance LS376 525HP Crate Motor-ls3-525-7-.jpg   2016 GM Performance LS376 525HP Crate Motor-ls3-525-8-.jpg   2016 GM Performance LS376 525HP Crate Motor-ls3-525-6-.jpg   2016 GM Performance LS376 525HP Crate Motor-ls3-525-1-.jpg   2016 GM Performance LS376 525HP Crate Motor-ls3-525-2-.jpg
2016 GM Performance LS376 525HP Crate Motor-ls3-525-3-.jpg   2016 GM Performance LS376 525HP Crate Motor-ls3-525-5-.jpg   2016 GM Performance LS376 525HP Crate Motor-ls3-525-10-.jpg   2016 GM Performance LS376 525HP Crate Motor-ls3-525-11-.jpg   2016 GM Performance LS376 525HP Crate Motor-ls3-525-12-.jpg
