Notices
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
2001 SS Camaro 1 of a kind
Old 06-27-2017, 02:02 PM
blackcamaro01's Avatar
Default 2001 SS Camaro 1 of a kind
Year: 2001
Make: Chevrolet
Model: Camaro
Price: $10000
Mileage: 77685
Location (State): WA
Color: Black
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Up for sale is my pride and joy. A black on black 2001 Chevy Camaro SS with 77,678 miles. This is a well thought out build – starting with the engine, an LS2 engine block, the right performance parts and the professional labor to make it all come together into a reliable high HP machine. But it is not only a powerful engine, the transmission, suspension, chassis and brakes have all been properly upgraded to ensure the car performs at its best and guess what, IT DOES!
The car dyno run at 511 RWHP and 522 RWTQ without using the NOS system.
I am listing below the parts and part numbers of all parts purchased. I am also including photos of all receipts I have from purchases and labor. I am also showing the Dyno results.
All modifications were performed and completed when the car had 61,750 miles. In other words, the car has run for 16K miles in its current state and no issues to report. All modifications were performed by Fame Automotive in Redmond, WA
So, on to the mods list:
Engine:
· 6.0L LS2 long block (Texas Speed & Performance TSP 402 C.I.D. LS2/L76)
· Texas Speed Forged 4340 Crankshaft
· Diamond Pistons 4.005" -10cc Dish (#112-11550R1)
· K1 6.125" H-Beam Rods, ARP 2000 Bolts
· ARP Main Stud Kit
· PRC 225cc As-Cast Aftermarket Heads, 68cc, PRC .650" Dual Spring Kit
· GM MLS .058" head gasket
· ARP 12-Point Head Stud Kit
· GM LS1/2 1.7:1 Rocker Arm Set with Comp Cams Upgraded Trunion Kit
· Crank pulley modified w/ pin and lock kit.
· New Idler Pulleys
· New Power Steering Pump
· New Serpentine Belt
· Vortech V-9 F Polished supercharger w/ after cooler (Serial #39856)
· Vortech maxflow Mondo bypass valve
· 8-rib SC pulley and belt for 8-10PSI (smaller pulley 3.12”)
· John Lingenfelter (Weiand) intake manifold
· K&N Air intake and filters
· N.O.S system and Purge injection installed
· 70 shot injector size
· High flow (quite) inline fuel pump installed
· Super Comp coated headers
· Bassani BX complete Exhaust system w/ X – dual rear split exit
· All necessary harness extensions for LS2 conversion / optional
conversion package that included the LS2 timing cover with camshaft
position sensor, LS2 valley cover, and plug-n-play harness extensions for
the camshaft position and knock sensor harnesses. (Required if you are
installing the engine into an LS1 vehicle)
· Tuned on Vortech/HP tuners software
Transmission / Rear End:
· Rebuilt transmission w/ improved hydraulics and 7 planetary gear set up
· B&M Shift Improver Kit for GM 4L60E transmission
. Moser complete 12 bolt rear end w/ True Trac Differential 3.73 – 1 gears,
. 3.75 carbon fiber driveshaft w/ U-joint, Carbon fiber driveshaft loop
Suspension:
Hardtop boxed sub frame connectors
· Hotchkis Sway bar end links
· Hotchkis Comp lower trailing arms rear
· BMR Fab Control arms front
· Hotchkis frame sliders and poly bushings
· KYB AGX 10 way adjustable struts front and rear
· Eibach lowering springs
Brakes:
1 piece cross drilled / slotted front brake rotors
Stainless Steel braided brake lines
This is without a doubt one of the best and well balanced 2001 Camaro you’ll find. It took some time, planning and a lot of money to get it there, it is now your chance to reap the benefits of it all.
Additional pictures of the car and receipts/bill for all work performed are located here:
https://1drv.ms/f/s!Ak7O9fQPEiW9itpjAV8PFZJ_Qc8J4A
Attached Thumbnails 2001 SS Camaro 1 of a kind-camaro-1.jpg   2001 SS Camaro 1 of a kind-camaro-2.jpg   2001 SS Camaro 1 of a kind-camaro-3.jpg   2001 SS Camaro 1 of a kind-camaro-4.jpg   2001 SS Camaro 1 of a kind-camaro-5.jpg
2001 SS Camaro 1 of a kind-camaro-6.jpg   2001 SS Camaro 1 of a kind-camaro-7.jpg   2001 SS Camaro 1 of a kind-camaro-8.jpg   2001 SS Camaro 1 of a kind-camaro-9.jpg   2001 SS Camaro 1 of a kind-camaro-11.jpg
2001 SS Camaro 1 of a kind-camaro-10.jpg   2001 SS Camaro 1 of a kind-camaro-12.jpg   2001 SS Camaro 1 of a kind-invoice-1-pg-3.jpg   2001 SS Camaro 1 of a kind-invoice-3-pg-2.jpg   2001 SS Camaro 1 of a kind-invoice-5-pg-2.jpg
Last edited by blackcamaro01; 09-21-2017 at 06:28 PM. Reason: adding cold start video
Old 07-13-2017, 02:54 PM
HCI2000SS's Avatar
Beautiful car and great setup for that price! Good luck on the sale
Old 09-15-2017, 11:59 AM
mounaki's Avatar
Still got it? If so text me 8476516721
Old 09-21-2017, 06:29 PM
Default No reserve on Ebay
http://www.ebay.com/itm/2001-Chevrol...ZZR1HD&vxp=mtr
Its up on e-bay with no reserve, currently at $9300
happy bidding
Old 09-22-2017, 10:18 AM
Default Sold sold sold
Done and done sold for $11,100
Quick Reply: 2001 SS Camaro 1 of a kind
