Turnkey lq4/ls3 carb to pan with msd box
2003 Lq4 stock block honed and decked, crank was polished and all new King racing xp bearings installed. Stock rods and pistons with new rings and arp rod bolts. Meling (black) high volume high pressure oil pump. New Gm f body oil pick up tube and windage tray. F body oil pan with Ict block off plugs and plate. Howards Asa camshaft and hardened push rods, new hydraulic lifters and rollmaster double timing chain with adjustable crank gear. Ls3 823 cylinder heads decked and valve job with new lunati behave valve Springs good for .590 lift installed with arp head bolts. Ict billet Valley cover with custom breather set up installed. Edelbrock super Victor 4150 single plane intake. Demon 750 custom carb with annular boosters installed. New prw sfi flex plate with stock a Delco starter. Stock truck coils with heatsinks and msd 6010 ignition box. New ls1 ac Delco waterpump with Ict billet spacers and manual tensioner to fit truck accessories.
THIS IS A TURNKEY ENGINE FOR $7000
WILLING TO SELL AS LONG BLOCK, SHORT BLOCK OR ANYTHING INBETWEEN
Less than 25 miles on fresh build
