Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
TH400 LT1/LS1 Swap parts
Old 05-07-2016, 12:41 PM
Junkyard60's Avatar
Default TH400 LT1/LS1 Swap parts
Category: Drivetrain
Price: $1
Location (State): FL
Item Condition: Used
Engine: LS1/LS6, LT1/LT4
LS Engine?: Fits LS Engine
I have a bunch of LS1/LT1 swap parts left over from my last swap. List is everything below. Pricing is shipped unless noted next to it. For quicker responses please text 813-731-5072.
93-97 F-Body th400 Conversion Crossmember w/ th400 transmission mount- 125 shipped
Stock rearend to th400 quartermaster driveshaft - 200 shipped
Old 05-07-2016, 03:00 PM
Junkyard60's Avatar
Timing Chain, T/A, ECU/Harness, front timing cover, balanced and hub, rear main seal, heads and Manifolds/Ypipe SOLD
Old 05-07-2016, 05:07 PM
Newbomb's Avatar
What's up with the welds on the crossmember?
Old 05-07-2016, 06:23 PM
Junkyard60's Avatar
Its the transmission mount, the ends had to be cut and rewelded, but it comes off with the bolt and nut on it, the crossmember is fine.
Old 05-07-2016, 09:03 PM
Newbomb's Avatar
Brain fart, looked damn near the same color! If you'll do $100 shipped, I'll cover PayPal fees. Shoot me your PayPal address if so. Thanks.
Old 05-08-2016, 05:40 AM
Junkyard60's Avatar
PM sent
Old 05-08-2016, 08:35 PM
FIVEPOINT7's Avatar
Stock LT1 heads? Any work done to them? Are you willing to pull off the crank balancer, hub, and timing chain cover?
Old 05-09-2016, 12:26 AM
Junkyard60's Avatar
Stock heads just disassembled. I am willing to pull it apart.
Old 05-09-2016, 07:05 AM
FIVEPOINT7's Avatar
PM me a price for those 4 things shipped to 27534
Old 05-09-2016, 08:36 PM
Junkyard60's Avatar
Updated
Old 05-11-2016, 03:57 AM
Junkyard60's Avatar
LT1 parts still available:
Opti, water pump, wiring harness and ECU, stock lifters, stock push rods, stock cam, rotating assembly, oil pan, block, power steering pump, th400 crossmember converter, flywheel, th400 to stock rear driveshaft.
LS1 parts still available:
88mm MAF, O2 extensions
Th400, ignition panel and hurst promatic shifter still available
Old 05-12-2016, 06:27 AM
Junkyard60's Avatar
Still have the parts listed in the comment above. Let me know if you need anything off and LT1 open to offers for everything
Old 05-18-2016, 03:48 PM
blacktrans97am's Avatar
I'm interested in the wiring harness. I assume its a 96? What kind of condition is it in?
Thanks,
Old 06-03-2016, 12:06 PM
Junkyard60's Avatar
Post updated on whats left.
Old 06-06-2016, 09:33 AM
Junkyard60's Avatar
transmission and shifter sold
Old 05-26-2017, 10:11 AM
sherman8r's Avatar
Still got that crossmember?
Quick Reply: TH400 LT1/LS1 Swap parts
