Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
alumastars, Custom Martin Smallwood Performance Cam, springs, etc..
Old 05-10-2017, 01:02 AM
4bangermustang's Avatar
Default alumastars, Custom Martin Smallwood Performance Cam, springs, etc..
Category: Accessories
Price: $1
Location (State): AL
Item Condition: Brand New
LS Engine?: Fits LS Engine
Custom Martin Smallwood Performance Cam. Solid Roller Lsx
Spec'ed for a 427" twin turbo setup. Specs are: 252/256 .750/.720 117+5. It's brand new, never used. I did slide it into the motor, but it never was fired. I have since changed the setup, so switching up the cam. This is a 3 bolt ls setup. $250
A pair of exhaust trim rings made of carbon fiber. Hole size looks to be around 4-3/4". Some minor scratches from laying around. $40.00
Weld Racing AlumaStar 2.0 Polished Wheels part # 788-510276. Excellent cond. never drilled for screws. comes with metal valve stems. Would look as good as new with a little polish.
15x10. 3" Backspacing. 4.75 bolt pattern. $600
Drysump oil pan. $150
injector bungs to setup dual injectors. $40
PAC 1324 springs, used. Only switching because I needed bigger. $180
Specifications
Part# PAC-1324
Dual Drag Race Spring - Bracket / High Lift applications
Mass (g) 152.0
Outer Spring I.D. (in) 1.175
Outer Spring O.D. (in) 1.625
Middle Spring I.D. (in) N/A
Inside Spring I.D. (in) 0.851
Install Load (LB) 275
Install Height (in) 2.000
Open Load (LB) 810
Open Height (in) 1.150
Coil Bind Max (in) 1.100
Lift Max (in) 0.850
Old 05-10-2017, 10:06 PM
more stuff added!
Old 05-11-2017, 09:37 PM
more pics added
Old 05-11-2017, 11:38 PM
Martin Smallwood's Avatar
Good parts from a good seller!
Buy with confidence!
Old 05-16-2017, 09:14 AM
Ttt.....
Old 05-25-2017, 12:50 PM
bump....
Old 05-26-2017, 07:43 AM
csjta2's Avatar
What is the Intake Port Volume?
Old 05-26-2017, 09:56 AM
Believe it's 252cc.
Old 05-30-2017, 02:08 PM
bump....
Old 06-05-2017, 11:54 AM
Ttt....
Old 06-14-2017, 09:17 AM
ttt...............
Old 06-16-2017, 01:32 PM
ttt...
Old 06-23-2017, 01:16 AM
bump.
Old 06-23-2017, 07:55 PM
zssman's Avatar
what bore are the heads set up for?
Old 06-24-2017, 01:32 PM
Was org going to put these on my 408 (4.030" bore). Then upgraded to a dart block and was going to put them on my 427(4.125" bore).
Brian
Old 07-03-2017, 03:57 PM
Ttt.............
Old 07-03-2017, 04:52 PM
mr spree's Avatar
PM Sent
Old 07-13-2017, 11:37 AM
bump..
Old 07-13-2017, 10:40 PM
liketowork's Avatar
Is the solid cam a turbo cam? How much over lap? Thanks
Old 07-14-2017, 12:03 PM
asubennett's Avatar
Great deal on heads and crank, should move quick.
Quick Reply: alumastars, Custom Martin Smallwood Performance Cam, springs, etc..
