396ci LT1 engine
396ci LT1 engine
Category: Engine - Complete Motors
Price: $4200
Location (State): NY
Item Condition: Used
Engine: LT1/LT4
LS Engine?: Non-LS Part
396ci LT1 built for boost. The motor also makes for a nice mild NA setup as well (~400rwhp NA). The compression ratio is 9.0:1 and is built to handle a good amount of power. It made 610rwhp (Mustang dyno) in the previous configuration at 11psi. This engine is in perfect running condition and ready to go. Zero issue, fully assembled, clean fluids, very low mileage (less than 1500). The car was properly tuned since day 1.
This engine was built with a lot of input from Jeff “LJ” Stevens a while back. For those who don’t know, Jeff knows his stuff and had one impressive LT1 F-body. This engine was spec’d very close to his personal 383 which went 9.9@139 in a full weight 96 Z28 with a baby Vortech S-trim blower. He later moved on to a Vortech YSi blower and made some big power. This engine is not your average LT1 build.
396ci LT1 engine
9.0:1 compression
Callies Dragon slayer 3.875” 4340 forged crankshaft
Eagle 5.85” 4340 forged H-beam rods
Ross custom 4.030” 2618 forged pistons (34cc dish)
Oliver 4-bolt billet splayed caps
ARP 4-bolt main studs/bolts
ARP head studs
Comp Cams 229/245 114LS custom grind cam (extra cam included with engine)
Comp Cams 220/232 114LS custom grind cam (currently installed)
FelPro 1074 head gaskets
FelPro 1284 intake gaskets
AFR 190 LT1 heads (current ported to 199cc)
-Ferrea 2.055” intake valve
-Ferrea 1.60” exhaust valve
-Comp Cams valve springs
LT1 intake manifold – ported, opened to 58mm
Crane Cams gold 1.5 roller rockers
Comp Cams Pro Magnum pushrods
Cloyes 9-3145 double roller timing set
58mm throttle body
LT1 fuel rails w/adjustable fuel pressure regulator
Melling M155HV oil pump
ARP oil pump stud kit
Stock LT1 F-body oil pan
96-97 LT1 timing cover
Billet keyed hub
Newer opti
Engine machining/labor:
-Clean block/final wash
-Bore 0.030” (actual 0.031”)
-Deck plate hone
-Deck block
-Clearance block for 3.875” stroke
-Replace cam bearings
-Replace soft plugs
-Install splayed caps
-Align hone mains
-Balance rotating assembly (internally balanced, neutral/zero balanced flywheel)
-Assembly piston/rod – full floating pins
-File fit rings
-Install cam bearings
The cam currently installed in the engine is extremely mild and essentially has a smooth idle offering near stock drivability. It’s by far the most mild-mannered LT1 stroker I’ve driven. I have an idle video that I made last week prior to pulling the engine. I’m also including an extra cam (custom grind for these heads) that makes significantly more power in this engine.
I have nearly all of the paperwork including flow numbers for the heads.
$4200
Located in Rochester, NY
