5.3 LM7 Garage Cleanout parts! And Misc other motors! CHEAP!
Category: Accessories
Price: $10
Location (State): VA
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Local Pick-Up Only in Warrenton VA!
Dirt cheap prices!
#BecasueLSparts<>Gold
#NotRetiringOnLSparts
If you are young and in a bind or have a really good sob story, let me know and I'll probably just give you what you need to stay on the road.
LM7 5.3 Parts and Misc. All parts from either 2005 or 2003 LM7 5.3 motors that are mostly spares from conversion motors.
- 5.3 crank w 24 tooth reluctor wheel. Dirty but good to go. All journals are nice. Comes with stock set of bearings. $40
- 7 - 5.3 pistons and rods Gen III. Used and dirty - re-ring and roll. Good for spares as needed. Stock bearings are all good. $5 each
- Stock Main bearings, bearing saddles, and bolts. Good. $10
- 8 - lifters. Good but need cleaned up. Sitting in Mobil1 now taking a bath. $10
- 2-3 sets of stock truck valve springs. $10
- 1 Set LS7 stock valve springs. 4300 miles from a Vette. Minty. Long! $40
- 1 LM7 truck camshafts. Good used condition. $10 each
- 2 Drive by wire throttle bodies. $20 each
- 1 Truck oil pans ( no windage tray, pick up, and dipstick) $20
- Set/pair of center bolt valve covers. $10
- Valley cover. Two knock sensor style. $10
- 2 mechanical fan assemblies. Plastic blades are not perfect. $5 each
- 1 truck water pump. Needs thermostat. $25
- Set of Truck exhaust manifolds. $40
- Misc Pulleys and power steering pumps and small parts. Let me know what you need... $5?
As the last two conversions come together, I will post up more items that I do not need.
Transmissions:
- Torque Flight 727 from a '83 FSJ Cherokee. Works! Drive it before I pull it. $250
Transfer Case:
- NP241-C Misc parts from a destroyed unit. Sometimes junkyard parts really are junk!
Misc:
- Pittsburgh engine lift hoist. Used three times - Minty. $125 (can deliver locally. keyword local. no BS.)
Needs / Trades:
- 2 - Cable operated throttle bodies
- Truck exhaust "Y" pipe - uncut.
- Good 105A truck alternator
- Bad oil pressure sensor (I bore them out as adapters for mechanical gauges)
- Early LS1 Perimeter bolt valve covers - set.
My wife thanks you for your purchases to clear out the garage!
PM me your # and I can text pics of what you need.
Thanks!
