1999 Camaro Z28 hard top ford 9 inch WELDS
Year: 1999
Make: Chevrolet
Model: Camaro
Price: $11000
Mileage: 100000
Location (State): TX
Color: Black
LS Engine?: Car has LS engine
1999 Camaro Z28 with T56 6 Speed transmission with desired Hard Top (less weight)
Body has over 100k on it but car has been rebuilt over the past year.
LS1 with around 75K on it
Motor was freshened up when put in. (rings, honed, decked and new head gaskets)
GM Hot Cam w/ upgraded springs and push rods
MSD Plug Wires
NGK plugs
SLP Lid
Kooks Long Tube Headers 1 7/8"
Magnaflow cat-back Exhaust (sounds mean and thumps pretty good)
17" Weld Racing Light weight wheels wrapped in Nitto 555's
Transmission was rebuilt around 15k miles ago by Eagle Transmission with a complete Master Overhaul Kit (1,2,3,6,R , sleeves Synchros, Bearing Set, Steel Forks Brass Shift Pads, Kevlar) Every gear shifts like butter
LS7 Clutch and Flywheel
Tick Performance adjustable master cylinder with W/ remote speed bleeder
Hurst Short Shifter
Quick Performance Ford 9inch rear end (less than 2k miles on rear end)
Yukon Nodular Center Section with 31 spline Eaton Truetrac Posi (3.70) gears
31 Spline Moser Axles
BMR adjustable Torque arm w/ relocation bracket and driveshaft loop
BMR adjustable Panhard Bar
BMR adjustable lower control arms
BMR Lowering Springs
Bilstein Struts
SLP Front Strut Tower Brace
