Destroked LS2
Destroked LS2
Price: $9900
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
Location (State): NH
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
- Seasoned LS2 block re-sleeved .10 over
- CALLIES MAGNUM XL CRANKSHAFT: Part number apz39v-XL 3.185 Stroke
- Callies Ultra Rods 6.350" @ 660
- Cam is 054-62135-62744-111+3. This cam is 231/237 at .050, .622/.600 lift and it is cut on a 111 LSA with a 108 intake centerline.
- Valve Springs are 73925K1
- Pistons are JE forged flat top with a -3.0cc valve relief to achieve 11.8:1 compression ratio
- Heads are Air Flow Research Mongoose 205cc heads with a 53cc Chamber
- GM Parts 88958679 Front Distributor Drive Cover Kit
- Holley 300-134 Dual carb intake.
- FAST 305007 Dual-Sync Billet Distributor
- 1803 500CFM Edelbrock carbs x2
- Edelbrock sequential dual carb linkage.
- Lunati Racing solid roller lifters
- Brian Tooley Racing dual roller timing chain
- Improved Racing oil baffles and oil pan with oil pan pick up.
- Texas speed oil pump
- Comp Cams pedastal roller 1.7 ratio rockers
- Comp Cams hardened push rods
- all ARP hardware
We consulted with the best of the best while building this, and no expense was spared to get a motor that will produce a good flat curve, fit almost any chassis easily and wind to the heavens.
The motor's concept was birthed here on LS1tech, based on the crank.
