(SOLD)MOZEZ Head Intake. Accufab. Nitrous Outlet
Category: Engine - Intake/Fuel
Price: $3500
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): NJ
Item Condition: Used
LS Engine?: Fits LS Engine
Interested, what size injectors?
Has this intake been used?
What's the RPM Range for this setup?
Will this make a good high RPM Boost intake, Turbo Setup?
what's the throttle body? do you have a part number and manufacturer, I'm using Holley Dominator EFi and will have to see if its compatible or I'd have to get one...
Has this intake been used? YES
What's the RPM Range for this setup? RPM range is dependant on your entire engine setup.
Will this make a good high RPM Boost intake, Turbo Setup? I spun my engine to 8000 RPM with it.
what's the throttle body? Accufab 6500
Do you have a part number and manufacturer, I'm using Holley Dominator EFi and will have to see if its compatible or I'd have to get one Part #4B-6500 and I have the GM TPS adapter so you can use a GM TPS sensor which will allow your LS1 harness to be a direct plug in
Hey man, I sent you a pm about Cary's contact info. Is he still in business? I cant find any contact info for magnatron nc, would you happen to have an email address or number for him? Thanks
