Bad coolant temp sensor or ground? Help asap
Old 06-18-2009, 02:53 PM
fbodyman1026's Avatar
Arrow Bad coolant temp sensor or ground? Help asap
My 99 trans am has been having trouble starting lately and finally threw p0118. It has a High Voltage reading from the coolant temp sensor. I did some searching and found that the sensor might be fine but it may just be a bad ground? When the car starts acting up the temp gauge goes to 0 but most times it is fine. What makes it randomly do this? I just bought a new sensor but Im not going to replace it unless Im sure it is. Thanks
EDIT: The car once again barely starts and then it it finally starts the idle goes up to 1300 and temp sensor is all the way down and the fans kick on. Any other ides guys I'm pissed.
Old 06-18-2009, 03:23 PM
bigboykilroy's Avatar
If you bought it already swap it, its a fast swap. then you will know. then you can do the more complicated if that doesnt work and look for a wiring issue.
Old 06-18-2009, 03:41 PM
alright I swapped it out for a new one and it the temp came up for a second then it went right back to zero and the fans kicked on for some reason. What do I look for now?
Old 06-18-2009, 06:49 PM
Which ground should I be checking for the coolant temp sensor. It looks like its in the back of the engine.
Old 06-18-2009, 10:10 PM
Notmyvette's Avatar
Not sure if sensors share the same ground as the coil packs (since I believe theyre in the same wireloom) but I know the coil pack grounds are on the back of the head, one wire for one side of the motor another wire for the other.
Old 06-19-2009, 08:00 AM
ok, do you happen to have access to HP tuners or a Tech 2?
THe reason I ask is, that its possible that the gauge in the cluster is defective. I'm curious what the PCM is seeing for a temp. but if no access, try..
Terminal 'A' is sensor ground, and 'B' is sensor signal to PCM, unplug the sensor and see if you are getting a ground signal. a logic probe works best for this.
Old 06-19-2009, 03:07 PM
No I don't or have hp tuners or any other software. I'm sure the gauge isn't defective though. Anyways I cleaned up the corrosion on like 4 random grounds on the front of the engine bay since I should try those before I go to the ones in the back. I then drove the car around and the ses light went off a havent had a problem since.
Is terminal A towards the front drivers side in the engine bay? If so I think the problem is solved.
Old 06-23-2009, 02:24 PM
read first edited post
Old 07-07-2009, 08:52 PM
kirkjames90's Avatar
i know this is kinda old but may help someone elese
i bought a coolent sensor from autozone and it gave me to same code stupid part was 20$ with tax
i went to orileys and got one diff brand and only 11$
Bottom line the cheaper one worked first try no codes nothing now which makes me think the duralast sensor does not work not sure tho but maby help someone
Old 07-07-2009, 09:06 PM
bt95formula's Avatar
Have you checked the connector/wires? My idle would drop and then catch itself, I thought it was just the tunning for the cam but one day while messing with the engine I bumped the wire loom that the coolant temp sensor goes in and the idle dropped and caught itself. I replaced the connector/wire (I think it is Delco#PT1798) Maybe this will help.
Old 08-24-2016, 12:58 PM
taws6ali's Avatar
Wow I am having the same problem you are describing 1999 trans am I did ls3 swap and kept same harness now my rpm malfunction (sometimes works fine) coolant temp sensor revently started malfunctioning (I rarely drive the car) I start it the gauge goes back to zero car randomly idle rough or stalls (I recent all the codes the car is running smooth but my fans stay on and temp at 0
When I drive when the problem occurs I feel like a hesitation then a tug and then sounds like the car is sucking in air like a vaccum... After reverting the codes drive it around the block a couple time now the only thing left is the temp gauge rpm sensor and fans staying on
Old 03-19-2018, 09:57 PM
Dylanlars's Avatar
Bringing up an old topic if anyone can chime in. My car started doing this! Bought a new sensor $35 bucks and still same issue. The 3 wires going into the sensor were exposed so I tried to tape them up. Is it more likely a short/ground vs a bad sensor? 1998 Z28 stock
Old 03-19-2018, 10:40 PM
ChopperDoc's Avatar
This really seems to be a simple ground issue. I'd check the wires for continuity at either end. When you throw a temp sensor to ground, it will read the lowest possible reading. This also occurs if signal is lost. Either way, these sound like old wires cracking and shorting out somewhere.
Look at the bright side though, you can clean up your engine bay while your digging through the harness checking stuff out. I'd open up that old crappy loom and chase the wires down, all the way to the pcm. It's not hard, just tedious. Re wrap everything back up with a quality loom and tuck as needed, once you figure out the problem.
I do this on purpose to my IAT sensor, to force the engine to pull a specified amount of timing when I flip the switch. It grounds the sensor out and makes it go to the lowest setting.
Old 03-19-2018, 10:50 PM
Dylanlars's Avatar
The wires going to the sensor and water pump have already been re-wrapped. Wondering if because there was exposed copper on all 3 wires by the pigtail if that’s where it’s shorting. Coil packs have new ground
Old 03-19-2018, 11:02 PM
Dylanlars's Avatar
Old 03-19-2018, 11:30 PM
ChopperDoc's Avatar
I would replace the wires there on that corner where the damage is. At a minimum pull the wrap off and see how much damage there is.
Old 03-19-2018, 11:37 PM
Dylanlars's Avatar
Okay is there fuses or resistors in between the sensor and the gauge? There’s 2 larger diameter sections within the wires.
Old 03-19-2018, 11:39 PM
Dylanlars's Avatar
Old 03-20-2018, 12:04 AM
ChopperDoc's Avatar
No, it's just straight wire. It looks like someone wrapped over the factory loom.
Old 03-20-2018, 12:09 AM
ChopperDoc's Avatar
Here's one with that "area" unsheathed.
Attached Thumbnails Bad coolant temp sensor or ground? Help asap-img_2006.jpg
Quick Reply: Bad coolant temp sensor or ground? Help asap
