burnout in reverse?
Old 06-06-2011, 09:56 PM
gxp-miller-gxp's Avatar
Default burnout in reverse?
i was wondering if anyone ever tried doing a burnout in reverse this way your not sliding forward and getting flat spots? just a thought of mine..
Old 06-06-2011, 10:02 PM
ANTICOP RAM AIR's Avatar
reverse has a much lower gear ratio, most guys do a burnout to at least second gear... and a lot of them would probably get a lot of hop.
Old 06-06-2011, 10:07 PM
chaman's Avatar
Old 06-06-2011, 10:43 PM
lol it was just a thought i had.. diddnt rlly think it would work
i already drive a fwd car with a sideways v8, what do you expect?lol
Old 06-06-2011, 10:56 PM
TheJPGXP's Avatar
Originally Posted by chaman
Pretty much.
Old 06-06-2011, 11:10 PM
1CL3ANSUP3RSPORT's Avatar
Talking
Donuts in reverse
FWD RULE lol
Old 06-07-2011, 09:39 AM
ill do it and if works ill film and show you all lmao
Old 06-07-2011, 09:44 AM
AnnivSS's Avatar
And if you spit your transmission out in the street we'd like to see the video as well. Btw, theres no way in hell the track officials will let you do this. If youre on street tires you shouldnt be doing a true burnout anyways, drive around the water and give it enough throttle to spin em a little bit to fling whatever water you did pick up then give it the beans.
Old 06-07-2011, 03:45 PM
the closest track doesnt ever have a way to go around the water hole, i just have to go through and i just try and spin it off after going through it
Old 06-07-2011, 04:08 PM
TheJPGXP's Avatar
And they didn't know my car was FWD.
Old 06-07-2011, 05:26 PM
haha are you talking about the burnout contest when they made you go through it?
Old 06-07-2011, 07:54 PM
TheJPGXP's Avatar
Yep. It has a V8 so it HAS to be RWD, right?
Old 06-07-2011, 09:40 PM
ls4door's Avatar
Im pretty sure something would break or sound horrid if you gave to much throttle in reverse.
Old 06-08-2011, 07:54 AM
LS4:20's Avatar
I did this once, one BALD tires.. Well, tried.. I assumed the 100% FLAT tires would spin in any direction, but to my surprise, I caught a BUTTLOAD of grip and just that tap on the gas pedal set me back about 4 cars lengths... Lol
Old 06-08-2011, 07:56 AM
rvd9431's Avatar
get your $3000 ready to replace the trans after you try
Old 06-08-2011, 09:12 AM
higsy's Avatar
The question is WHY ???
Old 06-08-2011, 09:21 AM
JessmoMonteSS's Avatar
This ^ x 9,567,202,245
Why ANYONE would want to do a reverse burnout is beyond my comprehension. Your tranny is in my thoughts and prayers.
Old 06-08-2011, 09:56 AM
TheJPGXP's Avatar
Why not?
I thought about doing a rear wheel stand, the back of my car is light enough, I've gotten on the brakes hard enough to lift both rear tires, wasn't trying it to, just happened during an event. Anyway, I quickly decided not to. Would be cool to see.
Old 06-08-2011, 11:54 AM
hot2005's Avatar
i wouldn't try it, 305 hp in reverse doesn't sound smart
Old 06-08-2011, 01:16 PM
TheJPGXP's Avatar
Originally Posted by bjohn
You are probably about to add another account name to your list in the sig
Vidz or it didn't happen!
Bite me, if they didn't disable the first one, I'd be using it.
3 wheeling videos, in one of them both lift a little.
https://ls1tech.com/forums/ls4-perfo...eos-4-3-a.html
https://ls1tech.com/forums/ls4-perfo...os-4-17-a.html
Quick Reply: burnout in reverse?
