Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
2000 Camaro Part Out (Built Short Block, T56 and others) Low Mileage!!! 78k on body
Old Dec 2, 2012 | 06:56 PM
Radcannon's Avatar
Default 2000 Camaro Part Out (Built Short Block, T56 and others) Low Mileage!!! 78k on body
Category: Accessories
Price: $1
Location (State): MI
Item Condition: Used
LS Engine?: Fits LS Engine
2000 Camaro Z28 Cherry Red. $1500
Stock rear end, stock fuel system, stock interior with aftermarket speakers, stock alarm, comes with spare and body harness and dash. 78k miles on the body. Mickey thompson 255's R16 in the back almost brand new. Front tires are new also.
The bad, needs new rear brake lines and some jumper lines to the abs module. Some of the body kit is missing. The bumper is cracked, there are two small dents in the car that are not bad and easily pullable. The car looks great from 10 feet but once you get up on it you can see some scratches and scuffs. Could use a new paint job.
LS1 Short Block. ~10k Miles $2000 OBO
Built by Automotive Machine Performance Machine Shop in Fraser, Michigan
Have full specs on weight and balance of rotating assembly, rings gapped for nitrous. Motor never had nitrous plumbed
Timing Chain - SLP Double Roller Timing Chain = http://www.summitracing.com/search?k...le-55000&dds=1
Oil pump = http://www.summitracing.com/parts/mel-m295
Cam - Camshaft specs are 226/226, .585 in./ .585 in., 112 lobe separation angle.
Pistons - Mahle Forged = http://www.summitracing.com/parts/mle-ls1314905f04
Rods - Eagle H-Beam = http://www.jegs.com/i/Eagle/356/CRS6125B3D-1/10002/-1
Bearings - Rod - Clevite = http://www.jegs.com/i/Clevite/695/CB663P10/10002/-1
Bearings - Main - Clevite = http://www.summitracing.com/parts/cle-ms2199p10
Reciepts for Everything. Can provide video of engine running before removed and pics of engine.
Brand new never fired 799 heads with dual beehive springs and valves. Built for a turbo motor. - $600
Willing to reassmble long block with the following: (Contact for price and details and we can work something out)
Above heads 799 and LS6 Stage 2
Pushrods - CCA-7639-16
You specify head gaskets
LS1 - Intake (Have an LS6 intake but is an additional price)
42# injectors - $200
LS1 Intake - $150
T56 $1700
Shifts like it was new
Spec Stage III Carbon Clutch less than 10k miles
B&M Ripper Shifter
Master and Slave cylinder included
(Also have a center console if needed) Camaro and Trans Am
Manual Pedal Set for 4th Gen F-body $75
McCleod Fully Adjustable Master Cylinder (NIB) minus the stainless steel braided line - 250 (New it was 440)
I misplaced this one and bought a second one because I thought I lost it in a move but then found it.... my mistake your gain
2000 LS1 Wiring Harness $200
*Forgot to add* 93 TA Gauge Cluster ~60k miles - $50
Also have some old school stuff
TH350 - $600
Built TH350. Alto red-eagle clutches, upgraded valvebody/governor, shifts firm and hard like a shift kit, comes with vacuum modulator too. It was built as a fully manual trans that still had automatic functionality. Has two dyno passes but absolutely no wear can still see the ink stampings on the clutches. Will include automatic star shifter with cable. (300 dollar shifter and cable).
The bad on the second dyno run I heard the trans starting to screech. I stopped the run and pulled the trans out and took the front pump off to find the sprag had knife edged and started scraping the drum. The front drum is fine but will need a new sprag. That was the only damage done to the transmission because I noticed it and pulled it apart right away. It was my fault because initially I didn't think I was going to build my engine to rev so high.
Between the trans/shifter/tc I have about 1600 bucks. Tired of it sitting in my garage, was always just going to put a new sprag in it and put it in another car. Well now I have 3 projects and still no need for this transmission.
It is open for people to look at. Also for an additional 30 bucks I can throw in a 67 Camaro crossmember powder coated black. Something else I have absolutely no need for. In addition I probably have an extra turbo 400 polyurethane trans mount sitting around but would have to look.
I am willing to separate parts, and work deals. All prices are negotiable.
Also willing to provide a complete LS swap for 93-97 Fbody or 93-2002 V6 - $5000
Including the following:
Manual Trans Center Console
LS1 Listed above assembled with heads
T56 Listed above
Aluminum Driveshaft
K-Member and steering rack
Headers (Old pair not the best but will get you going)
LS1 Harness modded to fit your application (I can do custom harnesses have done quiet a few)
LS1 PCM with tune for engine (O2 sensor delete and setup to run rich)
Pictures can be provided please let me know. Videos also available.
Old Dec 3, 2012 | 09:55 PM
Radcannon's Avatar
Bump for some offers. Get them coming in
Old Dec 4, 2012 | 08:26 PM
Radcannon's Avatar
bump....
Old Dec 5, 2012 | 07:51 PM
Radcannon's Avatar
Forgot to mention I have a McCleod adjustable master cylinder NIB minus the braided line. 250 new it was 440 with the stainless steel braided line
Old Dec 6, 2012 | 09:53 PM
Radcannon's Avatar
Bump it up... still available. Someone is interested in the short block, have someone interested in the transmission for a little below my asking price and have the transmission conversion parts sold. Also have someone looking at the body.
Still have:
Clutch Master cylinder stock
799 casting heads (brand new fully built, was built for a turbo motor)
LS1 Intake
Headers $75 pickup (rough just come pick them up you name price)
Exhaust $150
TH350
Wiring Harness
Cluster
42#lb injectors $200
Also will let the roller go for $1000 dollar minimum price you could make money if you part it out
Other miscellaneous parts if desired just ask
Old Dec 10, 2012 | 09:14 AM
Radcannon's Avatar
Bump
Everything is still on the table, got someone coming out the 15th for the short block and the harness is gone.
Items are:
Roller - 1500 with the mickey thompsons in back and new tires up front 1200 if you bring your own wheels. This is a good deal 1000 was too low will sit on it until offers come in.
2010 799 Casting LS2 heads fully assembled with LS6 springs brand new $600
Headers - 6 pack of beer (can have teh exhaust too cut in two places to remove)
Coolant crossover/bleed line in good shape - 50
2000 ECM - 75
LS1 Intake -150 with fuel rails and TB
42# Fuel Injectors - 200
Motor Mounts with all bolts - 40
Coil packs with harness and on LS1 brackets - 80
Radiator and E Fans - 75
Aluminum Driveshaft - 150
Willing to ship and can do local drop-offs in exchange for gas. I go out of town the 18th want to get most of this stuff gone.
Got other small stuff if people are interested anything on the car is available. Picture available upon request.
Old Dec 13, 2012 | 11:36 PM
Radcannon's Avatar
to the top. make offers just want this stuff gone. Worst I can do is say no but you might be surprised.
Old Dec 19, 2012 | 01:53 AM
jenkns7's Avatar
What color is the interior? Leather seats?
jenkns7's Avatar
Also is it a Ttop car?
