1999 Camaro Z28 6-speed, T-Tops *SOLD!*
Year: 1999
Make: Chevrolet
Model: Camaro
Price: $5000
Mileage: 145500
Location (State): AZ
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
It made 400 rwhp and 403 torque on a Mustang Dyno.
Performance:
Ls1 346c.i. 5.7L Short block 140k
PRC Stage 2.5 5.3L CNC Ported Heads
Prc .650 dual springs
TSP Magic Stick 3 237/242 .603"/.609"
Cometic gaskets
Professional Products Red fuel rails
F.A.S.T. 36# Precision Flow Injectors
LS6 Intake manifold
BBK 85mm Throttle Body
SLP 85mm MAF & harness
SLP smooth bellow
No EGR
Pacesetter Ceramic Long tube Headers 1 3/4"
TSP Off-Road ORY (no cats)
Fabricated Borla Adjustable Catback (2 out the left)
LS2 Timing Chain
LS6 Oil Pump
New GM LS7 Lifters
Chromoly Pushrods
ARP Head Bolts
Hypertech PowerStat 160 Thermostat
MSD wires with tr-55 plugs painted coil packs
SLP lid heated up to fit the 85mm maf
Transmission & Rear:
Ram powergrip Stage 3 Clutch Assembly
Aluminum Flywheel
Hurst shifter
Hurst Leather Shift ****
Skip Shift Eliminator
Master Cylinder Drill Mod
10 bolt
3.42 gear 4 channel traction control car
Suspension:
Sam Strano Lowering springs
Koni Yellow Shocks/Struts
BMR Adjustable Torque Arm w poly bushing
BMR Lower Control Arms
BMR Subframe Connectors
BMR adjustable panhard bar
SLP strut tower bar
Wheels:
Stock 16" Trans Am wheels
Goodyear 245/50/16, with a lot of tread left.
Brakes:
Baer Eradispeed 2 piece Front rotors
RotorPros Rear Rotors drilled and slotted
Duralast Gold Cmax Pads
Painted Red brake calipers
Interior:
Tan Leather from 2001 Camaro Front and rear seats
I made a couple videos of the car at idle and one with some revs.
Idle:
The paint isn't perfect, it's not bad for a 14 year old car. There are some scratches, paint chips and some bubbling on the sail panel. The only issues with the car is the passenger window motor is pretty slow, the driver's window is off it's track a bit(still goes up and down just fine), and reverse sometimes pops out of gear. I was told it might be a worn out shift fork. The A/C does not work. The compressor leaks, but I have another compressor to go with the car. It shifts smoothly through all the gears, no oil leaks, and no issues with the rear end. I have the title clean and clear and a clean CarFax report. I have some of the receipts from the mods that were put on it and a dyno sheet.
Car is located in Phoenix, AZ.
Price: $5000
You can PM or email me with any questions or if you want specific pictures of something. My email is molivola86@hotmail.com. Thanks.
New price at $7000. I've been taking it for some night time drives a few times a week so the mileage will go up just a bit. I really would like to see this car sold soon!
