LS7 438ci built motor. 525-650rwhp+ potential
Price: $10500
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
Location (State): CA
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
The goods:
new alum 4.125" bore LS7 block
resleeved by R.E.D. (Steve Demirjin), billet main caps, ARP main studs over $5K total parts/machining
rebushed titanium LS7 rods, Katech A1 rod bolts, Autotec lightweight race pistons, Total seal Rings
Eagle 4.1" crank set up for wet sump factory style pump setup
Can be 11.5:1 compression (91) all the way up to 14:1 for e85/116 octane
depending upon head milling/head gasket choice
WCCH LS7 heads, cleaned up ports, Brian Tooley racing springs/titanium retainers, new guides, s/s exh valves, titanium intake valves, performance VJ
LS7 intake, LS7 fuel rail, LS9 injectors
hydraulic roller cam of your choice 550-650rwhp+ potential. Brian Tooley would spec the cam for you.
LS7 lifters, Brian Tooley pushrods
ARP head bolts, MLS gaskets, LS7 rocker arms, Melling oil pump, LS2 tchain
front/rear covers, valvecovers, coil packs
Doesn't include harmonic balancer or accessories/water pump or oil pan
Can be run dry sump with external dry sump system (ARE/Dailey billet etc)
Currently shortblock is at the machine shop awaiting assembly (has 24x reluctor wheel now... but can install 58x if you need it). The heads/intake etc are at my house and freshly done by WCCH with zero miles also.
I can install Morel 5206 link bar lifters for a more race oriented setup for additional cost. I would opt for a billet Katech tchain as the only real upgrade and rebuild the rocker arms with the Comp Cams trunion bearing rebuild kit (you pay the difference). If you buy the Comp Cams trunion kit I can install it for $100 labor. Factory rocker arms are extremely light and durable when rebuilt.
This would make for one bad *** street motor and equally nice track setup.
I have put about 2K miles on my other car which is an LS7 powered RX-7 making 580rwhp approx.... totally streetable as would this combo be depending upon cam choice. Can take a 150hp nitrous shot if you wanted to spray it. I never did.
Currently setup for 11.5:1 compression (91 octane friendly). Could be lower with custom head gaskets.
I can ship anywhere via Forward Air trucking for FREE if you pick up at the terminal. If door to door cost goes up a couple hundred dollars and you would pay the difference.
Use the upper blue map for this rate.
http://forwardair.com/locations/falocations.htm
The green map below it is their extended locations and the price goes up slightly if you pick it up at one of these terminals. If you want door to door delivery there is yet another charge ($55 or so).
Fastest way to reach me is email. Please email my username at hotmail dot com
$10,200 Located in the SF Bay Area.
Monday bump. Made the shipping free if you pick it up at the terminal.
I have pics I can email/text of the heads/intake/inj/rails/rockers etc. The shortblock is at my machine shop awaiting further instructions. They have all the parts for assembly. Main question is 24x vs. 58x wheel.
Lowered to $10,200 with free shipping
Keeping the 90mm cable TB for another project.
I do have a polished 90mm DBW TB for $300 with purchase of the engine.
