Ridetech 4th Gen Coilovers
The install is a straightforward, bolt on setup. On the front and rear, we send out upper mounting plates that bolt into the shock towers (shown in the pictures). Depending on the skill level, you're looking around 2-3 hour installation time. Let me know if you guys see anything in the pictures that brings up a question!
Front mounting style...
Rear pictures...
Here's a link to the kit - http://www.ridetech.com/store/1993-2...m-level-1.html
2" is where the kit is designed to be set up at. You'll still have the spanner nut to adjust the ride height so you can raise it up or lower it about .5" more if you'd like.
In the kit, the standard rate for the front is a 14" 350 and the rear is a 12" 200. We can also change out the spring rates for different styles of driving or preferences.
I hate to say it Josh(an please don't take this the wrong way), but those are terrible combined standard spring rates for a 93-02 F-body! I know you said that they're available with different spring rates, but if places like Summit Racing and Jegs will be carrying the F-body coil-over kits with the standard spring rates, then a lot of people won't be happy with them.
IMO, going with a 14" 500 lb.in. up front and a 12" 175 lb.in. in the rear would make for better for handling car, 550-600 up front would actually be better but I see Hypercoil doesn't make anything higher than a 500 in the 14" springs.
For the length of the shock and the weight of the car, the 350 works very well. I haven't had any complaints at all, even with the customers that are doing autocross/road racing events.
From the real world testing and calculating the spring rate by the motion ratio, we feel that this is the best spring rate for drivability. If you're looking for a maximum performance, corner carver, I would then suggest a stiffer spring rate. In most cases, I would have the customer call with weights, engine/transmission information, and dimensions, but I don't think the spring rate is out of line for a good driving, handling car. Hypercoil builds 14" springs up to 650lbs as well.
That's why I made the suggestion about using 12" springs, with spacers if needed.
IMO, 12" springs would offer 3 more additional spring rate options above 400 lb.in. (425, 475, 550), cost less , and weigh less than going with 14" springs with +400 lb.in. spring rates. Actually with a 93-2002 F-body 10" springs are all you need if you're running +400 lb.in. spring rate up front. You can also get quality 1" or 2" coilover spring spacers so you'll still have all the same adjustability range as with the 14" springs. Anyway thanks for the reply even if it was 5 months later; still better late then never!
PM sent!
I put it on my 2000 Firehawk and have about 500 miles on it.
Right now I'm messing with the shock settings. I started out in the middle on all shocks.(10 clicks from full soft) I firmed up the fronts to 15 clicks and I like it better, but now the back seems a little floaty. I am going to firm them rears up a little.
Anyone care to share their settings and setup?
I installed a Huron APS style TT kit and with the added weight and the springs/shocks being wore out, it rode like crap and bottomed out constantly.
I talked to Sam about coilovers and the only kit he recommended was the Ridetech, but wasn't happy with the front spring rates. He said he would spec me something different, but it's been so long, I can't remember what it was.
I have my ride height set pretty low. I'm trying to achieve "the perfect, panty dropping" stance.
I know a little about a lot of things, but spring weight and shock dynamics are not on the list.
