Twin on3 70mm Turbos, Twin Turbo Intercooler, Two Wastegates, BOV
Category: Engine - Power Adders
Price: $750
Location (State): IL
Item Condition: Brand New
LS Engine?: Fits LS Engine
Decided to do a single turbo setup in the mustang. Will trade for New Borg Warner S480 turbo. Will do $750 for everything in pictures.
I bought these Used Local and they are almost new.
All items have run time, and a few trips around the block. No dyno time, no passes.
Turbos are twin 70mm ON3 Turbos. .70 A/R on compressor side, and .96 A/R on exhaust housing painted with hi-temp paint. Both are T4 flanged, compressor discharge is 2.5". They come with oil feed fittings & flange and the return flange.
Wastegates are a CX Racing 44mm piece. They have the valve seats, v-band clamps, It will include the hot side for the flanges. You can either reuse them or order new ones, up to you. They have a 12lb spring in them, that's what they came with.
BOV is a CX Racing that has the v-band clamp, I will also include the v-band & charge pipe.
Intercooler is also a CX Racing piece that measures 27"X12.5"X3.5". Twin 2.5" inlets and 1 single 3" outlet.
