Old 04-25-2016, 04:57 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension Guides
Print Wikipost
Intermediate Steering Shaft Replacment
Old 12-23-2014, 08:02 AM
customit's Avatar
Default Intermediate Steering Shaft Replacment
Hi Guys,
I have a 2001 Firehawk, so I already have the LS style intermediate steering shaft, but there is far to much movement in the u-joints which is giving me sloppy steering.
I would rather not replace it with a used part, with the possibility of just getting the same problem.
Has anyone found a NEW supply for these, or a manufacture of replacement kit specifically for the Camaro/Firebird LS1 setup.
thanks
Old 12-23-2014, 07:41 PM
redbird555's Avatar
Bump I need the same thing. I've been contemplating make my own from jegs parts
Old 12-23-2014, 10:29 PM
Daniel Richards's Avatar
same issue here, my upper u-joint is shot, but i've got the v6/lt1 shaft with the rag joint (which is not the problem, i've checked).
I've asked in the past if there was anyway to replace the u-joints but never got a response.
https://ls1tech.com/forums/pontiac-f...r-u-joint.html
Old 12-24-2014, 08:38 AM
01ssreda4's Avatar
If you could get the spec on the joint I don't see why you couldn't look up the replacement in a parts catalog. Not all shafts are clocked the same either I found out the hard way when I went to replace my entire shaft. As a welder, I cut it and reclocked to to match the stock unit but I realize not everyone has that capability.
Old 12-24-2014, 10:05 AM
Save the manuals!
wssix99's Avatar
You may find this guide useful. http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
Most of the parts in the column have not changed in 40+ years, so the parts should be plentiful. You might call up a company that does column rebuilds and see if they can get you the new part.
Old 12-24-2014, 02:36 PM
just to be clear, the OP is referring to the u-joints circled in red in the attached pic. This is the part that connects the rack to the steering column.
Old 12-24-2014, 04:01 PM
Save the manuals!
wssix99's Avatar
Thanks. I was thinking about the tilt mechanism.
Old 12-25-2014, 03:54 PM
Orange Juice's Avatar
I melted the rubber bushing on mine. I ended up having one made. There is a shop that specializes in steering column and he had it done. It was stupid expensive. I also picked up one second hand just to have a spare.
Old 12-25-2014, 04:57 PM
redbird555's Avatar
I did some searching and found that the stock u-joint are much longer than the standard 3-1/4" ones borgesun makes or can be found on jegs. The good news is that I'm pretty confident one can be made. The column and rack are just D shafts, jegs sells these in the standard 3/4" size. The shaft in 18" increments is 20 bucks and the u joints go for 60 or so. In the end I'll still be over 160 for a new shaft....****
Old 12-25-2014, 06:58 PM
RockinWs6's Avatar
24 bucks used http://www.ebay.com/itm/98-02-99-00-01-Camaro-Firebird-Intermediate-Steering-Shaft-Joint-Knuckle-/121516323291?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c4aeff1db&vxp=mtr
Old 12-26-2014, 03:39 PM
dailydriver's Avatar
How long ago did GM/AC Delco stop making these brand new??
Old 12-26-2014, 04:00 PM
redbird555's Avatar
Ya I've seen those, but theres no promise they'll be any better than what I have. Even if they are they may take a crap in a few months anyway.
Not sure I found a part number and did a search and seems no one has them lol I suppose a dealer may be able to do a nation wide search though
Old 12-27-2014, 06:44 AM
RockinWs6's Avatar
I think your best bet is to buy a cheap used shaft then pull it apart, measure everything and find the proper parts. You can still drive your car and I'm sure someplace out there you can find joints that size.
Old 01-14-2015, 08:10 PM
Its at least a year and a half. That is when I was looking.
Old 07-01-2017, 11:38 AM
Heavyhitta40's Avatar
Default Steering shaft
So what all is needed to make the steering shaft...I'm in need of one bad and can't figure this thing out
Old 01-31-2019, 10:13 PM
Dub Wair's Avatar
Default 1994 Camaro z28 ls swap
I'm not sure if my shaft install procedure are correct but I'm having issues getting it . Should I connect the steering wheel end first or the bottom first? I do have a LS RACK AND PINION.
Old 05-16-2019, 04:51 PM
nitroheadz28's Avatar
Bumping this thread, swapped out my LT1 shaft for a used LS style and have some play in the joints.
Old 06-19-2019, 01:34 AM
I guess there are no resources for replacing the u-joints?
Old 06-19-2019, 07:24 AM
Save the manuals!
wssix99's Avatar
Sure there are. The stock ones can be rebuilt or aftermarket companies like Flaming River have parts for new/fancy ones.
Old 06-19-2019, 02:09 PM
This is exactly the information myself and multiple other gentlemen have been looking for, any sources for that info? Thanks
Quick Reply: Intermediate Steering Shaft Replacment
