10 Bolt Rear for sale
10 Bolt rear end out of a 2002 Pontiac Trans Am with 24,XXX miles on it. Here are the specifics:
Transmission: 6 speed
Gear Ratio: 3.42
Diff Type: Posi
3 Channel (ABS w/o traction control)
Sensors and brake backing plates are NOT included. Sale includes the rear end, the rear sway bar, the drive shaft, and the axles. If you need just the drive shaft or sway bar I am willing to separate those items. Rear end worked fine when I removed it. Only swapped it out to go to an S60 set up. The inspection cover is off so you can check it out before purchasing. Feel free to text or email with any questions.
Willing to trade for a clean ebony Trans Am dash hull or $300
Located in Spring TX
See CL listing for picks: https://houston.craigslist.org/pts/5443487038.html
SOLD
Gear Ratio: 3.42
Diff Type: Posi
SOLD
I would buy his in a second if I could get up there. Are you coming south any time soon?
Deposit sent. I don't need the sway bar if anyone needs to hit him up on that.
