What trans fluid do you guys recommend
I got a 98 Camaro.. all bolt on 60k miles just pulled the 4l60e added the hd2 shift kit and yank ss4000 converter just wondering what fluid you guys recommend
The cheapest Dexron VI you can find. "Dexron VI" is not a brand, it is a trademarked specification belonging to GM. So basically anything marked "Dexron VI" will be identical.
Dexron 3 is the older specification and many pro builders still use it; saves a few dollars.
As mentioned even tractor fluid works. I suspect ATF is 98% tractor fluid and 2% additives, including red dye.
Some experts here said to avoid Trick Shift; it does not meet GM'sor any other manufacturer's specification and I have read of it gumming things up.
LS1Tech Administrator
Received 1,468 Likes
Dex/Merc (which is the current Dexron III equivalent, and what was originally issued in the 4L60E), any brand is probably fine but I use Valvoline. I would/do use this in everything from a stock to a stalled/built 4L60E, and also older transmissions such as my TH350 (also built with higher stall.)
Some are well above others in terms of quality. They all have to be at least a synth blend, a few of them are fully synthetic.
I've been using the Valvoline Dex 6 because it's fully synthetic. I've heard great things about redline D6 also, though I don't think it's Dex approved.
