Lsa Supercharger on 6.0
Im really interested in this setup, and was wondering how must power can a 6.0 put down with ported heads, cam and a lsa supercharger? i've been searching around and the supercharger is inexpensive
SOme people in the conversion section here too.
After talking to some people that did the swap and talking to some vendors that sell prochargers and other supercharger kits, it's not cheaper. It cost about the same. A complete lsa swap kit cost $5300 and a intercooled procharger kit cost $5400. So the only real benefit is the different factor
You can find used LSA superchargers pretty cheap sometimes, but they don't have really high power potentially. I considered going with one, but after doing some research found I'd be producing a ton of heat trying to make the power I wanted. I ended up with an F1R procharger and couldn't be happier.
I am thinking im in the $2500-3000 range for the blower stuff on my C10. Its a iron 6.0 with adapter plates and a LS Concepts drive setup (Dunno how well it works yet as its still on the stand) I figure these things max out at around 700hp.... its still not too bad of a deal VS a complete kit for a mild build.
http://www.ctsvowners.com/forum/4-en...s-updated.html
harness mods??
thinking of installing a Lsa charger on my 2007suburban 3/4 ton with a ly6. I wasent sure what I needed for engine harness or harness mods. I work in a gm parts dept. so parts are pretty easy to get a hold of. just wondering if anyone has done it, if the would share a parts list. and would love some advice on cam valve springs etc going to be a daily driver so can't be too radical.
I haven't had it on the dyno but even with 19x12" wheel and 325/30/19 nitto's it will break the tires loose anytime in 2nd gear and have had it break the tires loose in 3rd at over 90mph. My seat of the pants guess is that it making in the 475-525 range at the wheel.
For accessory drive I used the GM LSA modified part # 19303242
