Lowered and too much camber
I cut the stock springs and installed the MM spacers a few days ago. I cut a hair less than the pictures in the "Lowering CTS-V with stock cut springs" thread shows. The car looks great; however, I brought it in for an alignment at Firestone today.
The tech came in and said that he can only pull the camber to -2.6 and -3 because the bolts are maxed out. How are you guys that are even lower getting -1.5??
I'm anxious to see what else they can't adjust...
The front camber should be able to be recouped to within spec at -0.9*. The rear typically bottoms out around -2.3*
That seems like a pretty reasonable ride height in the picture, they shouldn't be having that much trouble getting you back in spec. They may need to sacrifice some positive caster in the process.
Some suspension manufacturers apparently don't know what they're talking about, because longer bolts aren't gonna do dick for changing the camber adjustability on a CTS-V.
The Kent-Moore J-45845 (and OTC knockoff) are what you'll hear recommended to help adjust camber in the front. However, having owned two of them, I can tell you that they should never have been recommended for use with this car.
What you actually want is a SPC 83785 ($95), which reaches across the subframe and grabs both lower control arms simultaneously.
Thank you for the input, guys!
Let me clarify though. The front is dialed in to -1* on each side. The caster is 3.6* on the left and 6.2* on the right. The tech said that if he moved the caster any more towards factory spec, the camber would go more negative. Toe is 0.07/0.06 left and right.
In the rear, camber is -2.4 left and -3.0 right. Toe is 0.07/0.09 respectively. Thrust angle is 0.01.
I will see about lengthening the slots to give them more adjustment room so I can get this straightened out properly.
Yeah.. -3 will just eat tires. I went lower than you and I'm maxed at -1.5. which is not terrible. Would have like a teeny bit more but I think I can live with my -1.5
So I'm guessing that something didn't get tightened enough during the alignment.
On the way to work this morning, my steering wheel progressively went off center during a 40 mile trip. Pic attached. I attempted to pass a vehicle on a back road and the car was all over the road to the point that I almost lost control. Not good.
