6.0 keeps breaking ringlands
So in the past I always played with 4.8s and 5.3s with turbo. I've since turned my 2500 with a 6.0. Running 10psi on the stock motor was good for about 2000 miles and I broke ring lands. So I pulled the pistons and rods and put a set I had the rings gapped to 28 and 30 and stuffed them in it. Had some blow by but no big deal. Was good for 3 days and broke ring lands on cyl 2 and 7 running low 10s on the afr in boost so I really don't think it's a lean issue. The pistons have some black on the center of them but are still pretty clean. Also running on 91 or 93 depending on what I can get. Any thoughts
If they've broke that soon....you can be fairly sure it's a tuning issue. Although "tuning" does cover a wide range of items
And if you've got blowby, something is fucked, because you can be 100% sure it is not the ring gaps causing it.
What ecu are you running, is there anyone competent tuning it and checking for detonation etc ? And AFR's etc are accurate ?
10psi boost from what ? Under what circumstances did it break each time ?
ive been tuning it myself so their is no one but people on the forum helping me
blue 10% fuelfix lean spots.hpt blue knocking.hpl this is the log from the first engine. i wasnt logging when the second one blew
I guess really I didn't have much blow by till I broke so you can disregard that. Because after it happened it blew my valvecover gaskets out but I was an hour from my shop so I fixed them in a parking lot and sent it north
Which ringlands broke? Top, between the compression rings, between the lower compression ring and the oil ring?.. any damage to the support rail below the oil rings?
If it's not the top land, or not only the top land, it could just be too much timing at the wrong time in the power band.
The quote below... I'm curious too.
Yeah, timing advance is an interesting subject. I've been bit by it too. No detonation, yet stuff starts breaking. Stuff I didn't expect to break. Crank shafts, wrist pins (BBC stuff)... Lessons learned.
The thing I keep in mind now, that I didn't know or acknowledge in my younger years, is that any gain from additional timing advance is a net gain. Meaning, there are losses involved. But the gains outweigh the losses, producing an overall net gain.
The losses... any ignition point prior to TDC is working against the piston moving up in the bore. More advance = more pressure on the piston before it reaches TDC. In many cases, too much will cause detonation. But, it doesn't have to detonate to break stuff.
I always back my timing off a couple degrees in what I "think " is my peak TQ area. Does it help acceleration ? who knows, but if an engine wants less timing at its max efficiency point, Im gonna try to give it what it wants . I cant see it hurting anything to do that and the MSD 6012 I use for ignition makes it really easy to do.
I'm not sure where my peak torque is. It now has a 4.8 I had stuffed in it. The first engine broke all the ring lands and put the oil rings in the pan on 4 cylinders. Second engine just broke tops that I can see. I have not pulled the pistons out yet or the pan. But my ignition didn't change between the 2 engines
Another thing to consider is timing drift. Just because you are commanding 12*, doesn't mean the engine is seeing 12*.. could be seeing 15*. That's why you :
1. Read plugs.
2. Test and Tune at the track and go solely off MPH.
3. Put it on a dyno, start safe and work your way up.
1. Read plugs.
so i've just started tuning my 4.8/7875 combo but it appears peak torque has moved up from around 3500-4000 rpm with the 6 liter to 5000 with the 4.8.
i'm actually liking the 4.8 quite a bit. it's not a dog down low like I had assumed it would be. just takes another half second to light the turbo up.
where are you located?
